Question about American Standard Home
My one piece original porcelain sink and counter has an uneven hole where the stopper is to go; the new faucet I am installing will not sit evenly and leaks! HELP - how can I even out the sink or get the rubber stopper/washer to actually work? I tried silicone caulk and it STILL leaks...this is like the 4th faucet since we moved in some 24 years ago; the first 2 worked but the last always leaked and the new one is obviously not going to work either...
  • Clayton Jr
    Clayton Jr Jul 14, 2010
    Are you using plumbers putty?
    Scholar:
  • 67 Answers
If it is truly a porcelin top then you can use a product called plumbers putty available at your local hardware store. It will conform to the shape of the drain and provide a good seal. If this is a cast marble or resin type of product then plumbers putty will void any warranty and possibly discolor the sink. Ensure it is indeed porcelin before continuing and follow the manufacturers directions for installation. Good luck with your project.
Posted on Jul 16, 2010
Delta faucet will not hold water
The linkage to the drain stopper has to be adjusted so that the stopper seats when the rod is raised. If the stopper lifts out of the drain, it may be necessary to remove the lifter rod and insert it through the holes in the bottom of the stopper then reinstall. After this, pulling up on the faucet rod will force the stopper to seat rather than drop by gravity. The tradeoff is that you will not be able to remove the stopper without disassembly of the connection
Feb 18, 2013 | Plumbing
Hansgrohe 88509000 sink drain does not close completely, water slowly drains out
This could be caused by the installation. If the installer did not use plumber's putty between the the flange and basin it will not seal with the basin. Another possible cause is if the basin is not perfectly formed it will cause the flange to oval or not seat evenly. If this is the case it may leak between the flange and the basin or the stopper may not seat all the way down and it may leak between the stopper and flange.
Oct 16, 2012 | Hansgrohe 31060821 Metris S Single-Hole...
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
About a year ago I installed an American Standard Cadet lavatory faucet with the Speedconnect drain. When I fill the sink with water it leaks out very slowly. I have not had any success in repairing this...
Try adjusting linkage under sink,squeeze metal piece and pull off to adjust to different hole setting,you can fine tune with small screw on chrome rod,so you can pull stopper down tighter
Jan 30, 2011 | Home
Can't Remove Plug
loosen the nut comming out the back pipe attached to sink. pull back on the rod till the stopper comes loose.pull out the stopper but screw the nut back on till you are ready to put the plug back in.You dont have to attach the plug to the rod if you dont want to it can sit freely in hole and be removed just by pulling up on it personal preference
Jun 20, 2010 | Chicago Faucets CHICAGO FAUCET Mixing...
I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Bathroom sink needs new drain, leaks under counter
Is it a new sink? Most of the time if it's new you'll have to get more pvc pipe because the new tail piece that comes with the new faucets usually is either longer than before or shorter. Yes you can get another tail piece or you may be able to by a longer pvc piece to to hook up the the metal tail piece. Make sure you have the plastic seals inside the pipe where they attach together or it will leak. Once you have it all together close your stopper and fill the sink with water and then pull the sink stopper and watch for leaks if it dont leak then it wont leak.
Dec 30, 2009 | American Standard Cambridge 5' Americast...
Our bathroom pedestal sink is very slow drain and clogging -2 questiions: do you have to disassemble and take off sink mounts and remove from wall to get to elbow joint? I do not know how to disengage...
You shouldn't have to disassemble everything in order to get to the trap (elbow joint). Most pedestal sinks are designed so that you can get to the trap from the back (generally after getting down on your hands and knees and crawling around with a flashlight). Most sink stoppers that are worked from the faucet itself have a little bar that extends down the back of the sink behind the drain. It will clip with a little metal piece to a lever that sticks out the back of the drain before the trap. The lever goes through a hole in the drain and pokes into a hole in the bottom of your sink stopper. As you move the lever, you will notice that your stopper goes up and down.
Unclip the rod from the lever and you should be able to unscrew the lever from the back of the drain (don't loose the little gasket that sits inside the screw-cap as it keeps water from leaking out here). At this point, you can pull out the stopper and see what is going on. If cleaning off the stuff attached to your stopper doesn't solve the problem, you can then remove the trap to see if anything is clogging that. Hopefully, by this point, your sink clog has been identified and you just need to reassemble, making sure when you put your stopper lever back in that you actually get it into the appropriate hole in the stopper itself.
If this doesn't solve your problem, it's more serious and you probably want to call a plumber as the issue is either a clog farther along or a problem with the venting of the sink drain.
Aug 30, 2009 | Home
I installed a new sink and pop up drain assembly. But the drain drains very slow because the stopper does not go high enough. I have tried adjusting the pop up assembly.
make sure that the piece going in to the drain that moves your stopper up and down is all the way in the hole on the bottom of the stopper once that is in hold the rod down so your stop is up then attach it to the piece attached to your rod this should solve your problem good luck
Mar 11, 2009 | Belle Foret Bathroom Sink Faucet -...
Home Logo
245 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
