Question about Philips 42PF9431D/37 TV
My picture is off center when ever I use my HDMI inputs
My picture on either of my hdmi inputs is off center
ThaMp3Doctor
  • 8596 Answers
SOURCE: can't get sound through my hdmi
Try the easisest route first - unplug and replug HDMI cable into same port or the other hdmi port on the TV. Also, make sure the Monster cable isn't HDMI 1.3 - I'm not sure the HDMI ports on this tv are fully compat with 1.3.
If that fails, go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software" - read the specs and see if it says anything about audio loss on HDMI - many Philips have issues with the HDMI ports - they are not broken, but just need a software fix. Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Here are the notes I see:
BX23U-1.5.0.0_03531
Following problems are solved :
• Availability cablecard channel map.
• Improved info in the service menu.
• Improved picture quality and stability on HDMI.
• Installation of channels.
BX23U-1.4.0.0_03081
Following problem is solved :
• Issue related to intermittent video loss is solved.
Posted on Jun 09, 2008
Uzfresh
  • 14 Answers
SOURCE: magnavox 42MF531D black screen
Common issue I have come across when using any TV as a PC monitor. Best workaround i found is just dont change inputs or reboot the PC and the tv will pick it back up.
Posted on Sep 16, 2008
electronick
  • 505 Answers
SOURCE: Problem with the HDMI input
check with another source or cable. you likely have a bad hdmi input, this would require a new SSB module to fix.
Posted on Dec 07, 2008
dsacco86
  • 1077 Answers
SOURCE: HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
Posted on Feb 16, 2009
  • 56 Answers
SOURCE: My TV has 3 HDMI ports. Originally I had HD cable
Welcome to Copyright Protection, otherwise known as HDCP. Its hell.
Interesting article in Popular Mechanics for you below. Have a read. http://www.popularmechanics.com/blogs/technology_news/4212508.html
This forum may help. http://www.avsforum.com/avs-vb/showthread.php?t=842732&page=2
Posted on Oct 12, 2009
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
Philips blu ray bdp2205, no picture when connecting to Sony bravia via HDMI cable. Works on other TV just fine. Help!
Make sure that your input on your Bravia is selected to the HDMI input that you are connected to; and that HDMI video output is enabled. If after doing that you still do not have picture from it then try another HDMI input.
Dec 29, 2014 | Televison & Video
Klv 40s400a
TVs need an input to display a picture. Some TVs have several inputs and you must select the one you are using. Example: my TV has four HDMI inputs on the back. If I connect my PC to one of the HDMI ports I must select that input in setup to display My HDMI ports are labeled HDMI 1, HDMI 2, HDMI 3, and HDMI 4.
If I connect my PC to HDMI 3, I must select in setting HDMI 3 as the input.
Oct 16, 2013 | Televison & Video
Dead hdmi input
you are lucky both hdmi inputs aren't blown. The inputs are not repairable individually. You must take it to an authorized service center. They will probably need to replace the input board.
Sep 03, 2012 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
No picture being displayed when using hdmi input. sound is working but no picture
If tv otherwise ok then suspect hdmi cable fault, but are you sure you are on the correct hdmi input. Your tv may have more than one hdmi socket.
pete
Nov 08, 2010 | Televison & Video
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Motorola DSR505 HDMI problem
Check to see if input 5 has a audio in source via RCA jacks. Many times manufactures will give you multi HDMI inputs but only one that has RCA jacks in case you are running a DVI/HDMI cable. If input 5 does not have those RCA jacks you will not have sound. I know this unit has multiple HDMI inputs. Look to see if any of the other HDMI inputs also have RCA jacks.
I hope this helps,
Skyassoc
Jun 22, 2009 | Televison & Video
Broken HDMI Port for HP-R5072
The HDMI input along with others is located on the a/v control panel of which would have to be replaced. I haven't seen an input jack yet with a part number attached for any model. I would suggest call a service center for a diagnosis.
Jan 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Philips 42PF9431D/37 TV Logo
151 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
