Question about GE PTS25LHS
My ge PTS25LHS fridge will not hold its temperature after I adjust it and save the setting. What may be wrong? Or how can I get it to save the temperature setting?
SOURCE: GE Monogram will not accept freezer/fridge
My ge monogram gets warm every year this time of year. All of a sudden no ice and everything defrosts. We vacuumed vents up top last yr and it got cold again. What the heck???
Posted on Aug 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge profile bottom mount and temperature control
Since it's less than a year old it should have a pretty good service warranty. A relay or confusion on the mother board is most likely the problem. I could send information to put it into self diagnostics but I think you may come out better by calling your nearest GE authorized service center. If you hear the compressor clicking and or no movement of air below the unit unplug it just to prevent any further damage.Your refrigerator is too new for me to tell you how to work on it is what I am trying to say, Thanks Sea Breeze
Posted on Sep 13, 2009
  • 50 Answers
SOURCE: IFridge and Freezer too cold, temperature wont adjust.
you need a new thermostat e z to put on it takes a phillips screw driver the t.stat is hooked right to the knob that you turn to adjust the temp
Posted on Feb 24, 2010
TheMobilian
  • 8220 Answers
SOURCE: Fridge Not Cold Enough
You could do the simple things like clean the dust and stuff around the compressor condenser. Check the condenser motor. Good air flow improves performance and cost nothing to fix. Of course if you are experiencing a defrost problem the air from below gets choke out with ice buildup around the evaporator area. If you have frost on the backside of the freezer section changes is you have a broken defrost heater.
Posted on Apr 19, 2010
heatman101
  • 43501 Answers
SOURCE: Freezer temperature is set to
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 03, 2011
My fridge and freezer stopped working. Nothing's running. It doesn't cool or freeze. None of the mechanical parts are working. Only the lightbulb turns on. What can be wrong?
if removing the mother board made no difference to the fridge operation then it would be logical that the mother board is faulty
These machines do not like power surges( can originate many miles away)
have a technician check it out
May 06, 2015 | GE Refrigerators
Ge psh25sgsa - Wont hold temperature
The water is from the heating element that does the autodefrost. There should be a drain for it though.
Dec 16, 2013 | Refrigerators
My GE GSHS6PGYSS refrigerator is about 1.5 years old. It is beginning to freeze certain items on some of the shelves. Hard boiled eggs are one of the ones that seem to freeze all the time. The digital...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jun 20, 2011 | GE GSHS6PGYSS (258 cu ft) Side by Side...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge runs continuousely
Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
Dec 11, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
GE PTS25LHS Logo
88 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
