Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The ice macker does not dispense the ice.
The ice macker does not dispense the ice. The ice makes and when you put your cup to push for ice nothing comes out. Not sure if the motor could of gone out and if so how do I go about obtaining it.
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
This could be something as simple as the actuating switch for the glass arm. I.e the micro switch has a problem. Your also correct in thinking that it can also be the auger motor.
Here are 2 on line sources for parts: There are many sources.
(You must have your model number)
http://www.appliancepartspros.com/
http://www.repairclinic.com/
This is the common auger motor for Whirlpool units:
http://www.repairclinic.com/SSPartDetail.aspx?s=b5a4c248ei1471493&PartID=1471493
Here are also a source of "how to information"
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
The 2 types of dispenser panels:
http://www.applianceaid.com/ken_whirl_disp.html
http://www.applianceaid.com/ken_whirl_disp2.html
Thanks for using FixYa.
Kelly
Posted on Jul 13, 2010
How do you remove the in the door dispenser cup and lever for cleaning
Depends on the make/model, but usually there are a few screws that go in from the front that hold the plastic arms in place along with the spring blade. Most of the time you need to remove the decorative plastic cover around the front of the dispenser to get at them. Pay attention to how things go together, or take pics before and during the process. It will save you a lot of headaches later.
Mar 20, 2015 | Refrigerators
The ice dispenser is not dispensing ice. When you put a cup under dispenser and push in, nothing happens. Its a Kenmore Elite, model 106.5896*701
here are some places to look, check the dispenser switch is working and also that it is being activated by the mechanizm, check that the auger is turning, if not is the motor getting power but not working? is the selector switch in the correct position and is it making contact...
Aug 22, 2011 | Kenmore Side by Side Refrigerator
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice won't dispense
the heater on the ice make is bad and not releasing the ice when it is suppose too.
Jul 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
197 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
