Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
Recently had a Belkin Wireless system install at home that keeps dropping the line in my room so want to use ASDL cable to connect to my computer what is the best modem card to get to do this
    Sergeant:
  • 202 Answers
Hello MatthewNicol
You wouldn't need an adapter card for your computer unless it does not support a hard-wired ethernet connection.
The DSL modem would connect directly to your computer via an ethernet patch cable just at it does currently to your Belkin N1 router.
Some DSL and Cable modems support a connection to a computer via a USB cable but this method is not recommended unless an ethernet connection is not available and not an option to install on your computer. (Connecting via a USB cable to your DSL modem will require a driver for the DSL modem, too.)
To connect (hard-wired) to your computer from your DSL modem, disconnect the ethernet patch cable that is connected to the WAN (Internet) port of your router and connect it, instead, to your computer. If it isn't long enough, replace the etherenet patch cable w/ one that is.
Before you make this cabling change, remove power from your router and from your DSL modem. Once you're finished w/ the cabling, restore power to the DSL modem.
Make sure the hard-wired NIC is enabled on your computer and that it is configured according to your ISPs requirements. (Just let us know if you need assistance w/ this.)
NOTE: W/ this arrangement, you will not have the ability to share the Internet w/ other computers via your router. You'd have to do so through your computer. (You cannot directly connect both your router and your computer to the DSL modem.)
If you need Internet connectivity for two or more computers, we could explore why your wireless connection is being dropped. I'd recommend doing that b4 abandoning the use of your wireless router.
If you'd like to look into that issue...:
(Q-01) Where is the router physically located in relation to the computer whose connection is dropping?
(Q-02) Is the router situated up high w/ clear LOS (line of site) to your computer?
(Q-03) If it is not in the same room, have you tried using one or more wireless repeaters?
(Q-04) Is the wireless adapter on your computer an N1 adapter?
(Q-05) If not, is the router configured to support your adapter properly? (802.11g or 802.11b)
(Q-06) If your wireless adapter is N1 are the other computers on your network (that are connecting wirelessly) using N1 adapters also?
(07) If they are, then set the router to N1 compatibility only.
(08) Do the same w/ Wireless G if all the computers' wirless adapters are 802.11g adapters. Include Wirless 802.11b compatibility ONLY if you have one or more computers on your network using 802.11b wireless adapters.
Ten Tips for improving your wireless network
If you have ANY other questions, etc at all on this topic, please, hold off on assigning a rating and choosing a "best solution" yet. Rather, post back here and let us know and we'll be happy to continue to work w/ you on this problem.
If, however, I answered your questions and you have no other questions or need of our assistance on this topic...
...would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
Thank you once again for using FixYa! Have a beautiful day.
BJ @:
Posted on Apr 20, 2008
  • B Joan Rapier
    B Joan Rapier Apr 20, 2008
    Markk7171 brings up a good point, too. That is that you can connect "wired" to your router rather than using its wireless connection if you like. This would give you a way to bypass using your router's wireless connection while at the same time continue sharing your Internet connection w/ other computers on your network.
    If, however, you are experiencing intermittent connectivity w/ this router both wired and wirelessly then there is a problem w/ the router. Please, let us know if that is the case.
    Sergeant:
  • 221 Answers
Your ISP should provide you with an external modem that would be connected to your phone line, then you would connect the modem to one of the wired connections on the back of the router, or directly to the back of your computer.
However, if you insist on an internal modem, I would suggest either a U.S. Robotics or Encore brand.
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
Internet keeps getting disconnected.Computer needs rto restart
there is nothing to do with adapter... you need to check with some other laptop to isolate where is the issue...
if your laptop works fine without dropping connection then get a replacement for your belkin adapter...
if your laptop also looses connection, then you need to check your wireless router...
Jul 24, 2010 | Belkin (F5D8231-4) Wireless Router...
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
Belkin N1 wireless router drops offline
The connectivity issue with your Belkin router could be due to a couple of different items. Your ISP might even be able to shed a little light on the subject.
I would also go to Belkin's website, and go to the support area by clicking on Support Center in the left pane of the sight. You can then search for your product number. With the results that you receive, you will be able to see what version of firmware they have, which is like doing a software upgrade on your computer. There should also be a step by step process on the website for you to install the firmware. I would do it from a desktop that is connected physically to the router.
Please let me know if you would like further assistance with this matter. Thank you.
Mar 27, 2009 | Belkin N1 Vision Wireless Router
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
I have recently bought a Belkin 54G Mod Router so that I could use my laptop with wireless connection in another room while my PC remained wire connected. I have installed it as directed but I keep losing...
a couple of question for you, is your wireless secure or did you enable security features like wep or wpa, how many people authorise people are on your network. if not secure, secure your wireless network, hackers like to kick people off their own system, upgrade the firm ware on your router, for the latest compatibility it will fix issues that arise and finally do a bios upgrade on your laptop.
May 26, 2008 | Belkin Computers & Internet
Cant connect
Hi! Did you go into the router configuration through IE (Internet Explorer)?
May 24, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at http://192.168.0.1) and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
150 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
