Question about Vizio L42HDTV 42 in. LCD Television
The Tv will turn on for a sec or two then turn off; no input
The problem started a few years ago; Turn on the TV and it would shortly turn it's self off you would turn it on again and it would come on.
This afternoon we tried playing a movie on the dvd player and changed the
input then the tv turned off and was unable to turn on for no more than a few secounds. Is it worth taken it to a Tv repairman and is common problem? Is it something I might be able to fix my self I do have some electronic back ground. Thanks Chuck
  • 11,361 Answers
Will Not Turn On
First you need to do a self test diagnosis and then if it comes up with:
SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Do self test by pressing Input/Device and Menu at the same time for 5 sec. the set will show a 2 digit seq. first blinks followed by a short pause then the second.
Dec 29, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
TV shuts off after 5 sec
Good Day,
TRY THIS:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH, ps; or call an authorized service center and ask them to give an estimate before you decide to repair.
Jul 30, 2008 | Mitsubishi WS-55807 TV
RCA F32450 TV problem
color ic on the blink.
Jun 16, 2008 | RCA F32450 32" TV
Powering on
needs a new flyback
Jan 01, 2008 | RCA HD52W58 52" TV
No picture
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
Dec 05, 2007 | Mitsubishi WS-55807 TV
Oval shaped picture problem with Mitsubishi WS55807
Nov 21, 2007 | Mitsubishi WS-55807 TV
HELP
Oct 20, 2007 | Mitsubishi WS-55807 TV
Vizio L42HDTV 42 in. LCD Television Logo
130 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
