Question about Gaggia Titanium Espresso Machine
Gaggia Titanium brew unit blocked message, brew unit is brand new and not been used what is the problem?
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Posted on Aug 06, 2009
  • 109 Answers
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Posted on Feb 22, 2010
We have a five year old Gaggia Titanium regularly descaled. In recent weeks the flow of coffee has considerably slowed to a drip and we now get a message saying 'Brew Unit Missing'. The machine also now...
Remove the brew unit, find the 2 screws above the top shower the connects the discharge tube to spout. Remove screws and carefully remove spring and ball some have a plastic seat at end of spring. Clean tube make sure there is no coffee grounds blocking tube, reassemble and test.
Aug 23, 2010 | Gaggia Titanium Espresso Machine
Leaks water from bottom when brewing coffee or using steam unit
If it is coffee colored water, check the chamber under the white plastic valve behind the brew unit, that might be blocked with coffee grounds. If it is clean water one of the lines might need new o-rings.
Apr 14, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium - lack of water/steam!
I have a Gaggia Titanium and the steam valve is leaking can I get repair parts for it
Mar 12, 2010 | Gaggia Titanium Espresso Machine
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Jan 03, 2010 | Gaggia Titanium Espresso Machine
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
'Grinder Blocked' error message
The grounds chamber is clogged, you will have to open the machine and clean out the chamber on the side of the grinder, it is the one covered with the little door, you might be able to get to it if you dremove the brew unit.
May 03, 2009 | Gaggia Titanium Espresso Machine
Hi I have a gaggia titanium coffee machine it has comme up with an error message the the brewunit is blocked i have decalcified machine but no joy can you help
Remove brew unit, If you have the key that came with the machine use it to remove the shower screens and check for blockage.
Mar 29, 2009 | Gaggia Titanium Espresso Machine
Gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Dec 16, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
122 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
