Question about Altec Lansing ADA745 4 Speakers
Speakers won't turn on
The light does not come on and no sounds
  • wps1203 Jul 15, 2010
    they were plugged into a surge protector and come to think of it there was a big storm sunday and they haven't worked since. So maybe the surge protector is not working properly either AND the speakers are blown out. Am i better off tossing these ones and buying new speakers?
    Sergeant:
  • 212 Answers
Make sure you are plugging in your speakers into a surge protector.
Try pluging in speakers to another (known) working outlet
If unit still does not power on, then unit is blown out.
Posted on Jul 13, 2010
I have a Bose TV speaker, it won't work, the power light is red and when I turn it on its orange
you must test the output with another speaker and see if work or NOT. if work you must know the speaker is faulty. If not work, you must see the Unit can be faulty circuit sound. God bless you
Apr 04, 2013 | Bose Solo TV sound system - Black
The kenwood KDC-MP333 in my truck is connected to a set of kenwood speakers. But when I turn it on they won't work the stereo still shows the display but when I turn the stereo on it makes a sort of...
Disconnect the speakers and try it with another speaker or speakers not in the truck. If it works, the speakers or the wires to them are messed up. If it doesn't you probably damaged the output capacitor in the radio by turning it on without speakers attached. Realize that the speakers are part of the radio circuit and act as resistance. Without them, there is no resistance and it puts a strain on the radio.
Jan 02, 2013 | Car Audio & Video
Jbl speakers turn off on their own
Sounds like you have them plugged into the wrong jack
Jan 01, 2013 | JBL Jembe Two-piece Entertainment Speakers
On 2001 Crown Vic, radio lights are on, channels change,etc but no audio. Fuse issue or any other possibilities?
sounds like your speakers aren't connected properly. check your speaker leads coming from your radio and make sure they are positive to positive and negative to negative. if you're using an external amplifier,check your RCA cables and your speaker outputs on the amp. make sure thr remote turn on lead is connected, otherwise the amp won't even power on.
hope that helped, good luck
May 31, 2012 | 2001 Ford Crown Victoria
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
The "PROTECT" light indicator came on and now the
The protect light generally comes on when the is a short in the speaker cabling. as a test, turn on the mixer without any speakers hooked up. If it still goes into protect mode the problem is in the mixer. Take it to your local music store and have their tech look at it. if it doesn't go into protect, check the speaker cables by plugging them in one at a time. The bad one will send it into protect.
good luck
Sep 12, 2011 | Fender 150 Watt PA System
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
Speakers will not "turn on",
Hi. You might want to try a different set of speakers or try the Altec Lansing on a different computer to isolate the issue. This can tell you if the problem is with the computer's sound card or your speakers. If the speakers won't work with any PC, try checking if the wires are all good and/ or soldered properly. Be cautious while doing this. make sure the speakers are not plugged in to any power source. I hope this helps. :-)
Jun 04, 2011 | Altec Lansing ACS 251 Computer Speakers
Altec Lansing ADA745 4 Speakers Logo
191 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
