Question about Intel D945GCCR Motherboard
When i install (ide 80 gb hard disk) window .at the end when i check drive then only c drive space is 17 gb and drive d ,e,f are o zero now tell me what is the problem
    Scholar:
  • 71 Answers
First of all we have to be sure the motherboard supports that hard disk and D945GCCR definitely supports 80GB (IDE).
As you have just formatted and installed OS on C drive the rests are unformatted. So please first format those drives by right clicking on D,E and F drive - choose quick format. Then you find all are ok.
N.B. If you add the capacities of all drives it will be less than 80 - please don't get confused - it is normal - you should multiply that with 1024x1024x1024 to get approx 80000000000 bytes.
Posted on Jul 13, 2010
    Sergeant:
  • 260 Answers
Did you partition your hard drive into more than one partition? If so, then did you purposely partition your "C" drive to 17-20 GB? If it's only showing up 17 GB then the other partitions are not formatted yet, or they are formatted to a file format that Windows isn't capable of reading.
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
How do i set hds722580vlat20 ata/ide as a slave drive
Since it's an IDE hard disk, you'll have to setup disk jumpers, please check the following image:
josema_sv_0.gif If you want more information please see the installation guide at the following link:
http://www.hitachigst.com/tech/techlib.nsf/techdocs/4DD4DCCA11DE5EB186256D6A0061C8A8/$file/Installposter.pdf
Feb 21, 2011 | Hitachi Deskstar 7K250 80GB...
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
We are unable to load window xp on hard disc, before we only find the 32 GB in 80 GB hard disk ... we successfully installed the window xp, but when jumper setting done in accurate place, it shows 80 GB,...
I think this model is still an IDE type. You set the 32GB limit then jump the settings to read the full capacity of the drive. If you are trying to load XP OS from a blank drive.
First prime the hard drive, you can do low level formatting and use third party software to partition and format the drive. on FAT32 partition you can only use 8GByte to make the drive bootable. Make it primary if I remembered it correctly and active. Or use the NTFS format.
You can use also if it have the manufacturers' hard drive utilities to check the hard drive integrity. I know they have it. It also equip with zero fill to renew chain and links of the drive. Then partition, format, primary and active. Then load your OS.
Check also your CD disc integrity, scratches do make a lot of troubles. And also your cdrom/dvdrom drive.
Oct 27, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
Drive got deleted
hi, you could either replace the hard drive for a larger one or invest in an external hard drive, these are really cheap at the moment and you can purchase a 1TB (1000gb roughly) for less than £80. i recommend ebuyer, fast delivery and value for money. (can i plug ebuyer?)
May 02, 2009 | IBM ThinkPad G40 Notebook
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
SP0812N HDD 80Gb
this mainly depends on The Operating system, if your using Windows 2000 or above it should,nt be an issue.
sometimes there are limitations on 2 hard-drives sharing the same IDE channel on the mainboard.
Try putting the second hard-drive on the secondary motherboard slot, with it,s own individual cable.
If non of the above works, it,s possibly not formatting correctly.
you,ll need a program that zeros then formats the drive.
Hope this helps.
Mike @ Compurepair.
Feb 22, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Intel D945GCCR Motherboard Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
