Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
Sony KDF-70XBR950 Im getting a blue image on the bottom center of the screen. I cant see it when watching widescreen movies with the black bars. but full screen movies and broadcast programs its there.
  • 1 more comment
  • Biotox Apr 22, 2008
    I replaced the bulb in my Grand Wega and now I have a blue shadow on the left side of the screen which is on all video displays. It was fine and then the bulb went out. I replaced the bulb and now I have the shadow. Is the bulb in wrong or is there another problem?
  • tritonblue Nov 26, 2008
    same problem, 70" grand wega. i replaced the bulb and shortly after a blue fog appeared on the bottom of the screen. any solutions? triton.6691@yahoo.com thanks.
  • innercircus Jan 06, 2009
    I have the same issue with my 70 inch sony wega, I also just had my bulb replaced within the past month or so. and just my luck my 4 year extended warranty ended just before the wierdness started!
techman
  • 3130 Answers
SOURCE: blue shadow
You have a bad light engine or in Sony TV sets, it is called an Optic Unit Block Assembly. This is a very expensive part and should not be attempted to be replaced by a novice. Call an authorized Sony repair place to have this repaired. Good Luck
Posted on Sep 14, 2007
tvtek
  • 1284 Answers
SOURCE: no full widescreen on HD broadcasts
Do you know what the aspect and resolutiuon settings of the cable box are? What brand of cable box is it?
Posted on Nov 28, 2007
  • 139 Answers
SOURCE: The blue line appeared at the lower border of the letterbox
easy fix. adjust the vertical position of the image using the on-screen menu.
Posted on Mar 06, 2009
SOURCE: Sony Grand WEGA KDF-70XBR950 70 in
You need a new projection lamp.......(XL-2100 replacement DLP lamp)..... go to this web site to get the lamp you need for your TV model KDF-70XBR950 70inch----
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040980
------ This web site shows you how to install it yourself. ----
http://guides.fixyourdlp.com/sony/XL-2100U.php    --------- I strongly suggest that you get a SONY manufactured replacement lamp NOT a cheaper lamp from another manufacturer... it costs about $200.
Adelaide B.
Posted on Mar 07, 2009
  • 668 Answers
SOURCE: my Sony kdf-e55a20 Grand Wega 55inch TV that I
Unfortunately the Optical Engine will need to be replaced to fix the problem. It is a very costly repair. Most of these Optical Blocks run around 800.00 for the part it self and labor will vary between 180.00 and 270.00.
You could try to call Sony at 1800-222-SONY
and see if they could help out with the cost.
I hope this helps,
Skyassoc
Posted on Sep 12, 2009
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
Blue line across bottom of screen on a Sony LCD rear projection
Contacted Sony Eletronics and was told it could not be fixed . Sony
offered a great deal to trade in for a much better one : a 55" Sony Bravia valued at $ 2,000 for $ 825 . Not bad !
Feb 05, 2010 | Sony KDF-E42A10 42 in. LCD Television
Blue streaks on the screen of my kdf-70xbr950
This has a failing optical block. If you can do your own work there is a rebuild service on ebay
Feb 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Blue cloud on the bottom center of the screen Sony xbr 70
If this is a KDSR50XBR1 or a KDSR60XBR1,
It is a bad Optical Block and you need to call Sony at 1-800-222-SONY asap to get a exstended warrenty repair. If it is not, and it is out of warrenty I would still call to see what they will do. In either case, it is a Optical Block causing the problem.
Hope this Helps,
Skyassoc
Jun 28, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Mar 06, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
DVD WS does not display right on Samsung 40'' HD 1080P LCD TV
Check the aspect ratio of your widescreen DVD. I'll assume that your flat panel TV is widescreen, which would mean it has a ratio of 16:9. Some movies are even wider than that (i.e. 2.35:1), so it would be normal for you to see black bars at the top and bottom. Look for a WS DVD described as 16:9 (usually shown on bottom on back). This should fill your TV screen and not distort the image. If you still see the black bars, you will need to check your DVD menu settings for widescreen aspect, and supply more info on the DVD player and TV.
Nov 30, 2008 | Televison & Video
Blue shadow
Sep 14, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
