Question about Fisher and Paykel GWL11 Top Load Washer
Water dripping from inlet hose after wash has finished?
How can this be stopped
  • Rylee Smith
    Rylee Smith Jul 13, 2010
    By unplugging it
  • karen_legg Jul 13, 2010
    sorry maybe I havent explained it very well,
    the hose that fills the machine is dripping after the wash has finished, is it broken?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. No need to be sorry…You are right; if you have already checked the hose for any clogs then yes it has gone bad and should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 13, 2010
  • Rylee Smith
    Thanks for rating the solution, please post back for further assistance.
How do I stop it from dripping into the basket when the washer is off
The drip would be coming from the water inlet valve that is mounted under the console.
You can replace it. First disconnect the mains chord from plug and close the water inlet taps on the wall. Open the screws holding the console and turn it back. Make sure you don't drop it.
This will expose the water inlet valve. Check none of the hose clamps have come off or loose. If that is the case then tighten or fix the clamps. Otherwise you will have to replace the valve.
It is available from this online shop. See item 15 in the diagram.
ADMIRAL Washer Controls and water inlet Parts Model ATW4676BQ0
Aug 13, 2014 | Washing Machines
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
Our machine keeps dripping water once load is finished. We have turned off water and checked hoses as well as the water inlet valve. Everything looks fine. It is only when the hot water is on, I shut...
I would replace the inlet valves. Even though the issue is only a drip now, the failing hot water inlet will drip enough water to overflow and flood your floor if left unattended. The failure code you see is because the washer senses the water connections. It is telling you that there's no hot water available. Replace the valve- soon.
Good luck.
Jan 18, 2011 | KitchenAid KHWS02R Front Load Washer
When washer finishes cycle and spins out water will start dripping into the washer and will get the clothes wet if not taken out
You have a faulty water inlet valve which needs to be replaced. If it's cold water dripping into the machine then it's the cold water inlet valve.
Oct 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
When the washing machine is off, water continues to slowly drip inside the washing machine. If we turn off the water where the hoses are connected to the wall, the dripping stops. Any idea what might be...
Could be a build up of limescale inside the water inlet valves stopping them from sealing properly when they close. Unless you feel confident enough to take it apart you should get an engineer in to look at it.
Feb 02, 2010 | Kenmore Washing Machines
Slow drip of water inside the drum. Don't see no moisture but I can hear it dripping. No Moisture on the floor. Any ideas where it could be dripping from?
Turn the water faucets off and listen for the drip to stop.
If the dripping noise stops,replace the water inlet valve on the washer were the hoses connect.
Enter your model number in the site referenced here for parts.
www.appliancepartspros.com
Jan 24, 2010 | Maytag Washing Machines
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
When the washer finishes the spin cycle and I open it up to remove the cloths, the water continues to drip into the drum. What do I need to do to repair this problem.
It sound's like the water inlet valve is stuck open, it's located at the back of the washer, the cold and hot water hose's connect to it, you may need to replace it with a new one to fix the drip.
Apr 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
52 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
