Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Engine is running but the line no longer moves - it like it's out of gear
Sorry I can't solve it yet but same thing happened to me...I took out all the screws holding the case together and could see that the drive belt from the motor to the shaft had worn away or melted...at any rate I could see it was in shreds...Have to see if there is any way to replace that belt
Posted on Jul 13, 2010
  • 4 Answers
Check the belt inside it may have come off the spindle
Posted on May 23, 2011
I have replaced the starter in my mustang 3 times already because either the gear shatters or just winds up and doesnt turn the motor over
Maybe you have a run of bad parts. Maybe the engine is trying to run backwards because of ignition timing or a crack in the distributor cap. If it is a high mileage engine, the thrust bearings are letting the crankshaft move forward and backward too much.
Mar 21, 2014 | Ford Mustang Cars & Trucks
Can no longer shift gears in tacoma while running
Check the clutch cylinder and make sure you have no leaks and bleed it through good luck colin
Jul 09, 2017 | 2001 Toyota Tacoma
I have a 83 magna and after running it for about 15 km the bike no longer pulls. It almost as if I have it in 5th gear and going 30 km. I gear down the bike and when I apply the accelerator the rpms go up...
Sounds like the clutch can't take the heat any longer. It is the springs that are bad, but might as well replace the friction disks as well, because new ones will be thicker and cause more pressure.
Jul 26, 2011 | Honda VF 750 C Magna Motorcycles
I'm having trouble when I put the car in drive it's going through it's gear progression slow and it's idiling high I'm thinking it may be the transmission fillter since I had the transmission replaced...
Check this first. On the transmission there should be a small vacuum line that goes all the way to the inlet plenum, check that both ends of this line are are connected securely and that the line has no holes in it. This vacuum line governs the rate at which the transmission moves from one gear to the next. When the engine is running slowly, just above idle, the throttle plate is all but closed and the car will shift through the gears pretty quickly as there is no load and plenty of vacuum. If on the other hand when the engine is racing under load, with the throttle plate fully open, there is little vacuum and the transmission holds in gear for very much longer before up shifting. If this vacuum line is disconnected or leaking the transmission will interpret this as the engine under load and will be very tardy in up shifting.
Sep 08, 2010 | 1992 Buick LeSabre
Okay. I got the old timing belt out and found that all the teeth were gone where it goes around the crankshaft gear. I put a new timing belt on and lined up the marks, but when I rotate the engine several...
the marks on the belt itself will not line up with gear marks after rotating engine as long as engine marks line up you are fine however these are know to bend valves
Aug 21, 2010 | 1991 Nissan Pathfinder
Mk1 VW Polo drops out of gear on over-run
more likely to be a worn baulk ring.do yourself a favour and rebuild the box,its so much easier and will last longer.to test,apply slight hand pressure to gearlever in drive and over run if it slips out......its time for a rebuild....
Jun 15, 2010 | 1986 Volkswagen Golf
The cutting blade no longer moves, even when it is attached to the drive engine and the engine is running at high rpms. I think some kind of gear inside must be stripped out.
Mine was doing the same thing so I took the gear box cover off made sure it would still rotate then I packed it full of gear grease. That did the trick it runs perfect now. Mike
Sep 24, 2009 | Homelite Expand-It Hedge Trimmer...
Cranks won't move
Sounds like the clutch is worn out. It sounds like it is slipping so badly it won't transmit enough power to move the bike.
As far as only going in 3 gears with the engine not running, are you spinning the rear wheel while trying to shift it? The trans shafts have to be spinning to be able to shift through the entire gear range.Try shifting it with the engine running and see if you get all 5. If you do, there is no problem with the transmission.
Jun 12, 2009 | 1994 Yamaha GTS 1000
Trans still wont engage
If there is no fluid when you take off one of the lines (check both: the cooler might be plugged) while the engine is running, and there is fluid in the trans, then you have a bad pump inside the trans, or the valve body fell off. Either way, it's probably not going to engage. Ever.
May 06, 2009 | 1995 Ford Bronco
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
706 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
