Question about Kyocera Copystar 221 Black and White Copier
How can i hook up the scanner?
SCANNER TO MY NETWORK
  • 523 Answers
Hook the network cable to your scanner nec card on the machines, note that this machine has two nec cards, one for printer and one for scanner.
after that Go to the setting and under setting/Scanner Default create and ip address for the scanner. after you done from that go to the computer browser, type in the ip address, you can choose scan to smb or pc.
Scan to smb needs shard folder but scan to pc needs to run software on your computer on your pc.
Setup the sender list which you need to fill only the ip address of the machine as sender.
Go to destination setup the ip address of the computer you scanning to, the path is the shared folder name, and the user name and password of your computer and you good to go.
To make it easy for you, Provide me your email and i will attach the scanning manual to help you setup it correctly and you can always get back to me in any question.
Best Regards
Kyocer/copystar Expert
Posted on Aug 25, 2010
Hello Steffen, We have a 8830 scanner Synergix.
Hey Panos,
What are you trying to feed a paper roll or single sheets or are you telling me you cant feed the original to be scanned? Can you copy or print internal status pages from your Xerox?
But it sounds like thats not the problem as it isnt hooked up and your lappy as it dont have a serial port you only have USB...... but this is a network printer.... do you have a network or it is just a stand alone lappy?
So I guess.. stand alone lappy to Xerox.... you will need to network it... and if it just a stand alone lappy ie no network then you will need a non standard network cable called a crossover cable to go from scanner to lappy but you will also need to set up a network with them manually asigning IP's of each to be on the same network, then hooking with a crossover (normally red never blue) network cable, and you will also need the software installed on this lappy no matter which way we go
Spose you could try a serial to usb adaptor but they will have issues propally when trying to use that sort of interface on scanning, normally one has the print server that is an option on your scanner to interface with the likes of a laapy, so I dont think it would workor a good idea to go with an adaptor
Well come back with some more info because the more info you can give me about your problem the better i can understand it.. cheers
We are talking about one of these beastys.. User Manual
Cheers
Steve
Dec 16, 2011 | Xerox 8830 Copier
I need to make the scanner available on the network, the printer is networked OK but can't seem to figure it out. Can you help
Need to know what printer and how it's hooked up.
For instance, if it's an all in one printer (epson or HP etc) and it's hooked up USB to one computer and shared across the network, you can't share the scan capability across the network.
What yu'd have to do is scan to the computer that it's hooked up to, placing the scans into a folder that is shared across the network so anybody can access it.
If it's a network capable scanner with it's own Ethernet connection, then the process can be vastly different, but the scan function should be sharable across the network.
Jul 21, 2011 | Office Equipment & Supplies
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
I've connected my IR1023iF to the network. The printer and fax work fine but the scanner doesn't work at all.
If you've hooked up the copier via ethernet cable then it needs to be setup for scan to email, FTP or scan to folder (smb). This can be done through the copiers web interface which is accessed by typing the copiers IP Address into your web browser. If you've hooked the copier up via USB, then there is 'toolbar' software that you would use for scanning. If you need the software, let me know and I can post it on an FTP site. Just an fyi...I'm pretty sure that you can't hook up both ethernet and USB at the same time.
Nov 11, 2009 | Canon imageRUNNER 1023iF Black and White...
Can CanoScan be installed on two computers?
Most scanners including all-in-one printers can be shared acrossed a network. Hook up the scanner to one computer. At that computer, go into the control panel and to scanners (XP that would be printers and other hardware and then scanners). Right click on the CanoScan and click sharing. You can assign a name to the device. Go to other networked computer and add the device. You should be given an option to locate device on a network. Install the same driver and software you want to use with scanner.
Note: I'm not a Mac user, I've given instructions based on Windows XP/Vista. But, process should be similar.
Oct 19, 2009 | Canon CanoScan 4200F Flatbed Scanner
Can I share my Scanner on a Local Area Network?
Yes, one can indeed share a scanner on a Local Area Network. There are, in fact, three different ways to go about sharing the given scanner with a LAN. These include sharing your scanner over the LAN by making use of software such as FlexiHub, which is an application that serves the purpose of accessing and sharing a remote USB device, or several devices, over an IP.
This is the most common and effective method as it allows for the support of either Linux, Windows or Mac's. It's also quite easy to use and doesn't include any advanced settings. Finally, it also assists with the sharing of USBs and a serial device such as Bluetooth devices, printers, keyboards and fax machines.
The other two methods, which are considerably less common to use are the integration of traditional scanner sharing software which assists with accessing your USB devices when directly connected to your operating machine of choice, much like FlexiHub, as well as Windows functionality. Windows functionality allows for the sharing of a scanner to other computers by only making use of the Windows operating system.
What is USENET
Oct 17, 2009 | Canon DR-2050C Path-Through Scanner
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Networking and scanning?
Go to the compuetr that the device is directly hooked up to.  Go to your mycomputer and right click on the scanner, and click on the sharing link.
You might also access it from the printers control panel.
Oct 27, 2007 | Lexmark X5150 All-In-One InkJet Printer
My Canon Imagerunner 2200 won't scan.
Sorry that was actually me...after i posted...it asked me to register...so i did.
Okay, you need to download Canon Network scangear from the Canon website. then take your document...put it on the top feeder...turn you scanner online...open up microsoft word 2003..insert, picture....from scanner or camera select network scangear....custom insert....then scan. The machine needs to be hooked up to a network...but note...a simple cross over cable or usb between pc and the photocopier will not work.
Oct 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Kyocera Copystar 221 Black and White Copier Logo
278 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
