Question about Casio HR-100TEPlus Calculator
MRC function of my Casio MS-170TV
When i use the MRC function of my calculator what appears in the monitor is formatted in H/M/S format..What can i do with this?HELP!
SOURCE: Casio calculator MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Posted on Jan 11, 2008
SOURCE: Changing the % tax setting on my Casio calculator
MY TAX- AND TAX+ ARNT WORKING ... ANY1 NO HOW 2 FIX IT ?? PLZ ???
Posted on Jan 31, 2008
  • 21 Answers
SOURCE: casio MS-120TE tax rate
Look for "RATE SET" it is usually located on the % button. Press and hold the button and when the display comes up just the press the desired rate then press "RATE SET" again then clear
Posted on Sep 20, 2008
How do I program tax rate into my calculator?
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Posted on Nov 27, 2008
SOURCE: CASIO ms-7TV
To change the task number you must press and hold % (rate set) for 3 to 5 seconds, should appear tax XX %, now type your tax number and press % again and AC. To test type "100" press TAX + and the result should be 110, if your tax rate is 10% for example.
Posted on Aug 13, 2010
How to add function for complex number calculation on my casio fx 82 ms...anyone help
The calculator cannot perform any calculation on complex numbers. Sorry.
Aug 22, 2016 | Casio FX82MS Scientific Calculator
Could you please help me .. Is it possible to calculare irr with casio fx 82 ms? Thank you very much
Internal Rate of Return (IRR) Calculation Using Casio MS ...
? 2:32
https://www.youtube.com/watch?v=7Lvqp_E54Y0
Apr 13, 2015 - Uploaded by Nurul Amin
Internal Rate of Return (IRR) Calculation Using Casio MS Scientific Calculator ... +Nurul Amin i have a casio fx-82ms can ialso calculate IRR?
Discounting Basics on Casio fx-991ES and fx-82MS ...
? 7:24
https://www.youtube.com/watch?v=Xs7rq4JI3mg
Feb 14, 2014 - Uploaded by Sujoy Krishna Das
Discount calculations on Casio fx-991ES and fx-82MS calculators .... Internal Rate of Return (IRR) Calculation Using Casio MS Scientific ...
Jan 10, 2016 | Casio FX82MS Scientific Calculator
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
I have a Casio fx 82 MS and when i do calculations like 5/55 its giving me an answer of zero
Reset your calculator. If you choose an Exponential display format (Scientific, Engineering, Normal1, Normal2) select more decimal digits. Your current setting seems to display no decimal digits.
Oct 08, 2013 | Casio FX82ES Scientific Calculator
How do I use the fraction function on casio fx 300es
I will supply a link to a website for you to download the user manual in PDF format, You will need adobe acrobat reader or similar to view this. You will also find a link to download adobe acrobat reader if you currently do not have a PDF reader.
http://support.casio.com/manualfile.php?rgn=4&cid=004001132
I hope this helps.
Sep 13, 2012 | Casio fx-300ES Calculator
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
What are the parts of casio calculator
LBrown18062@hotmail.com My manual is 75 pages. I can email it to you. Please put Casio FX-115ES as the subject. Awaiting your response.
fx-115ES User's Guide
About this Manual
• The MATH mark indicates an example that uses Math format,
while the LINE mark indicates Linear format. For details about
input/output formats, see "Specifying the Input/Output Format".
• Keycap markings indicate what a key inputs or what function it
performs.
Example: 1, 2, +, -, !, A, etc.
• Pressing the 1 or S key followed by a second key performs
the alternate function of the second key. The alternate function is
indicated by the text printed above the key.
• The following shows what the different colors of the alternate
function key text mean.
If key marking
text is this color: It means this:
Yellow
Press 1 and then the key to access
the applicable function.
Red
Press S and then the key to input the
applicable variable, constant, or symbol.
Purple (or enclosed Enter the CMPLX Mode to access the
in purple brackets) function.
Green (or enclosed Enter the BASE-N Mode to access the
in green brackets) function.
• The following shows an example of how an alternate function
operation is represented in this User's Guide.
Example:1s(sin-1)1=
Indicates the function that is accessed by the key
operation (1s) before it. Note that this is not part
of the actual key operation you perform.
sin-1{D}
Keycap function s
Alternate function
Jan 19, 2011 | Casio FX-115ES Scientific Calculator
HOW DO YOU USE THE DEGREES MINUTE SECONDS FUNCTION
To convert an angle from degrees (decimal degrees) to the sexagesimal notation (deg, min, seconds) use the key [DMS] the one between [(-) and [hyp].
Everytime you press the key, the displayed result is cast in the other form
EX; 12.58 [DMS] gives 12 deg 34 min 48 sec.
Suggestion: If you are doing many calculations with the sexagesimal format, use the decimal degree format, and only when you find the final result do you convert it to DMS.
Hope it helps.
Sep 30, 2009 | Casio FX-115ES Scientific Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Dec 03, 2008 | Casio FX-260 Calculator
Casio HR-100TEPlus Calculator Logo
223 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
