Question about Intel Motherboard
Everytime i boot my computer a message appears that says "bootblock bios scanning for bios image in the harddrive" i dont have access even with the keyboard. what shall i do? can anybody help me. thanks
    Guru:
  • 551 Answers
Try flash to the latest BIOS version. Download the file, unpack it, copy the files to a bootable floppy, then boot off it.
http://asia.giga-byte.com/FileList/BIOS/motherboard_bios_7vt600p_f8.exe
You might need a floppy drive to boot this file.
Posted on Jul 13, 2010
What will i do if this message appear on the screen of my computer everytime i attempt to open it : Reboot and select proper device or insert boot media in selected boot device and press a key.
I dont know if youre are familar with bios settings, nut every time you start
the computer, you can press esc or del or something to load the bios. in the bios you can select the boot device. set it to harddisk.
Apr 19, 2010 | Microsoft Windows XP Professional for PC
When i turn on the laptop computer, a message appears: primary hard disk drive not found, fixed optical drive not found. No bootable devices: strike F1 to retry boot;F2 for set up utility. I tried but...
Your BIOS is looking for a drive to "boot" from and does not see your harddrive or CD-rom.
You may have a harddrive failure or bad drive controller.
One way to see is to load your operating system disc in your CD-rom and see if the computer sees the drive and boots up. If it boots, try to locate your "C" drive. If you can't locate the harddrive, it's a good bet it's damaged.
If the CD-rom doesn't boot, it is most likely a bad drive controller or cable.
Dec 30, 2009 | Computers & Internet
ACCESS A BIOS
I'm not quite sure what it is you exactly want here but if you need to get into the BIOS utility then as the computer is starting up repeatedly tap the Del key or the Esc key.
Regards.
Sep 28, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Award BootBlock Bios V 1.0 (Quad BIOS)
Try to change the boot order to boot to usb or floppy and try to flash the bios.
Aug 23, 2009 | Computers & Internet
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Award BootBlock V1.0
Hi.
The BIOS (Basic Input output System) on your motherboard has become corrupted and the computer can't boot normally. The Bootblock is a "failsafe" device that allows the computer to boot far enough to use the floppy disk drive, even though the rest of the BIOS code is scrambled.
How do you think this happened? The most common cause is people trying to "update" the BIOS and messing up the flashing process. Sometimes some particularly nasty viruses can wreck the BIOS code as well.
Now this might be fixable. You will need to download a known good BIOS from Iwill's website and the Award BIOS flashing utility. Then you will need a bootable floppy disk (DOS) to start the computer. You will have to copy the BIOS .BIN file over to the floppy beforehand and the flashing utility. There will be information on the Iwill website on how to flash the BIOS.
Here is a full detailed webpage on how to go about all this:
http://pages.sbcglobal.net/jefn/bootblock.html
I just did a quick Google search using the motherboard details you provided and came up blank ....
If you can't get the BIOS flashed and usable again then I'm afraid it's time for a new motherboard/computer.
Dec 30, 2008 | FIC AZ 31 Motherboard
Misplaced rompaq diskette
You probably need to change the boot order in the bios to make the computer boot from the cd rom before any local hard drives.
F2 is usually used to access the BIOS, you have to press it immeadiately upon seeing the first screen, which usually displays the name of the manufacturer, and from there you have to find the section to change the boot order.
Dec 08, 2008 | Compaq Deskpro EN PC Desktop
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
What cable?
This message is displayed the motherboard attempts to preform a PXE boot. In otherwords, it is attempting to boot from the network.
This message is displayed under the following conditions:
1) No boot device (i.e. harddrive, cdrom) was detected. (Remember, even with a fresh harddrive you will get this message because the harddrive does not have an operating system tellling the BIOS it is bootable.)
2) The BIOS is configured to boot from LAN (PXE) before the hard disk drives.
To fix:
1) Power down your computer and check all power and data cables (ALSO JUMPER SETTINGS!) leading to the HDD, CD-ROMS, and other drives.
2) Hold down the key to access your BIOS while turning the computer on from a powerless state.
3) Change the boot order putting LAN (PXE) boot last: I would do CD, HDD, LAN.
4) Exit and save the changes.
TIP: HOLDING F12 WHILE WHILE TURING YOUR COMPUTER ON FROM A POWERLESS STATE WILL BRING UP A BOOT MENU AND YOU CAN CHOOSE TO BOOT FROM CD, HDD, ETC.
Sep 19, 2008 | Intel Computers & Internet
Dell m65 bios password
dont know if there was a previous question to this.
but why cant you access bios and why do you want to access bios.
if it to reset password I have software thats boots up and can change or wipe passwords ,even with no harddrive.and also reset bios to factory standard.
Apr 09, 2008 | HP Pavilion dv6000z Notebook
Intel Motherboard Logo
122 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
