Question about Sport & Outdoor - Others
Have a Yamaha GP800 Waverunner that has been sitting for2 years and now after replacing the plugs, filter, battery it will not start. When pushing the green button nothing happens not even a click.
  • Brian Meloy
    Brian Meloy Jul 13, 2010
    It was in fact the fuel filter was not getting fuel. Once we cleaned the terminals it began to crank. We pulled the filter and re4placed it. Now it is running. A little sluggish but we are on our way to recovery. Thanks for the info.
  • Brian Meloy
  • 252 Answers
Hi Mr Budman
Assuming the battery is a new one that you have replaced it with, please check the following:
If the ignition light doesn't come on when you turn the key then check the earth strap from the starter motor, this is connected to the negative battery lead.
Make sure the battery leads are fitted securely, as well as clean. Remove each one and clean up the terminals with a wire brush, put vaseline on afterwards, this will stop them rusting out.
Make sure the safety switch is turned off.
If the above are both OK. Check that fuel is getting through. Twist the throttle with the side plastics off. Look to see if it moves the throttle cable. These get stretched, frayed or snap, especially with under-use. Replace with a new one.
Once you are getting a spark, make sure you have new fuel in there, as old fuel is bad. Change the oil too.
I hope this helps you and please vote for me.
Posted on Jul 13, 2010
Waverunner is abnormally slow accelerating initially, but will finally get up to normal speed
Pull your air filter out and also replace plugs. Overtime the filter will become saturated with oil and believe it or not the plugs can cause about a 10 mph drop if there going bad. But make sure your pump and impeller are not damaged also
Sep 18, 2013 | Yamaha 2004 WaveRunner FX Cruiser
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
We just bought a Yamaha 1100 waverunner, and it has a problem. We changed the plugs, fuel filter, and tested battery. It still starts ok, runs for a short time then all of a sudden cuts out and wont...
Sounds like your vent tube from gas tank is blocked causing fuel starvation. if its a 96WVT then rite under the seat by the latch are 2 tubes sticking out with a piece of hose to hold it in place, make sure they hav'nt slid down
Jul 06, 2010 | Yamaha 12V Air Pump
2000 waverunner starter wont stop
This is most often caused by a battery that does not have a full charge on it. The low amperage available from the battery causes the contacts inside the starter relay to weld themselves together and allow the electric starter motor to continue to run even after the starter button is pushed. Always start out with a fully charged battery and you will not have this problem.
Jul 25, 2009 | Yamaha 12V Air Pump
My yamaha 1100 waverunner will not turn on . I have a ew battery in it, but no power. They have set out side for the past 4 years. What do I need to check?
u need to push mode and hold it it will display ---- push aaaa that is the factory start code for that year if that dosent work let me know and we will have to find out what code you need if aaaa works after u push the code it should say start
Jun 27, 2009 | Boating
1995 yamaha waverunner 3 exhaust leak
pull battery tray and find the broken hoses
Jun 23, 2009 | Yamaha FZ 600 Motorcycles
I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
you have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
Jun 12, 2009 | Yamaha 12V Air Pump
2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
May 15, 2009 | Yamaha 12V Air Pump
Sport & Outdoor - Others Logo
238 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
