Question about RCA RP8078 5-Disc CD Changer
Setting up the player
I do not know how to set up this player. It was left behind at my house a few years ago without the manual, Can you tell me how to connect it to speakers? Does it need to be connected to a receiver and then connect the speakers to the receiver?
    Guru:
  • 257 Answers
The unit definately has to be connected to a receiver with a built in amp, and the speakers will then be connected to the reciever
Posted on Jul 13, 2010
  • Anita Williams Dec 10, 2011
    Thank You, I just obtained one from Amazon.com. It is a used one. Now where will I find the receiver with a built up amp and speakers. Since the CD player is Used where could I buy the used accessories.
I have a Jandy Aqualink RS and my waterproof handheld is not so waterproof. It went out a few days ago and today I had a power outage and dont know how to reset the time without the handheld??
the time isnt in the hand held there is a 9 volt battery in the aqualink behind the top panel replace then go to time set up in the set up menu of the PDA then after power outages it will hold time it will not erase programs you have set or your auxes that should fix that
Jul 08, 2014 | Jandy AquaPalm
How do I manually re-set the time on my Casio Exilim camera? I have set the worldtime etc, but it's about two and half years behind and I can't work out how to re-set it. This has been a problem...
Press MENU. On the "Set Up" tab, select "Adjust" then press cursor-right. Use cursor-left/right to move between fields, cursor-up/down to change them. Press SET when done.
The instructions are in the "Changing the Camera Date and Time Settings" section of the manual (page 165 in my copy), which discusses both the world time settings and the home city date and time. If you need a manual, you can download a copy from
http://support.casio.com/pdf/001/EXZ75_DI_e.pdf
Jul 14, 2011 | Casio Exilim EXZ75 Digital Camera
I moved into a house 3 years ago and inherited a Kenmore washing machine that is 30 years old and still working. The problem is the dial letter is worn off, so I am never quite sure what type of settings...
I too had a machine just like you. What I did was get a sharpie marker pen and slowly turned the dial and when I landed on a setting I would make that location. I would do that for all of the locations and test the water if it is cold, warm, hot and label appropriately. If you go to a store and look at the dials you will normally see three settings. On the left will be normal everyday setting, to the right is the more specialize settings and bottom is the permanent press settings.
Personally speaking I would be happy knowing where the hot and cold settings are and I can do all of my laundry. Good Luck and have fun
Jan 07, 2011 | Kenmore Washing Machines
Lightning hit my house my tv turned off and has never turned back on, checked the fuse seems to be fine do not see any charing anywhere?
Many years ago I was called to a house in the countryside because their TV wouldn't work. I arrived to discover that the TV looked perfect on the outside but when I removed the rear cover, there was no copper track left anywhere, just components on a bare pcboard. The aerial lead was without a copper conductor and the mains lead thee same. That was a direct hit.
I was called to another set with the condition of dead set. There was no external or indeed internal damage but the electrical surge has damaged the power supply. I repaired the power supply to find a line timebase fault. I repaired that to find a problem with the tuner, I wrote the set off to insurance as a total loss.
One can never tell what or indeed where the damage is with this sort of problem.
Hope that helps and stops you getting a large bill for a repair that may fail again.
Nov 09, 2010 | JVC AV-48P575 48" Rear Projection...
One speaker no sound
I just want to confirm that the solution on another page from francis 8 works perfectly ( http://www.fixya.com/support/t3709832-speakers_stopped_working_cannot ). We have two sets of Creatures in our offices, one had been shelved (by someone less persevering than me) due to this problem years ago and my set started this trouble a few days ago. Troubleshot everything, every cable, setting, combination, spare speakers etc - nothing worked. Opening the offending speaker and pulling back the metal weight behind the speaker cone was the solution for BOTH of our units.
Big smiles all around :-)
Note - When you've opened the plastic shell and loosened the speaker from its mounting, the the big round metal piece/magnet sits within the actual speaker 'cage', slightly behind the speaker cone. It's tight but movable and can be pulled all the way back as far as it can go inside it's housing, away from the speaker cone.
Not sure why it gets pulled forward, but it isn't fixed in position and so could clearly get bumped by dropping the speaker or a reasonable impact of some sort. Once bumped forward it would severely limit cone movement and therefore volume.
May 07, 2010 | JBL CREATURE II Computer Speakers
Dishwasher
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
SOUND NO PICTURE
Hello, You have a high voltage section problem I would not suggest fixing this set on your own. You will need to take this set to the shop. Because there are no user repairable parts inside of the set.
Sep 10, 2007 | Sony KV-36XBR400 36" TV
Samsung Yp-U1
hey i lost my set-up cd for yp-u1 and i got a new comp how can i downlaod music into it without the compr econgizing my mp3?
Aug 04, 2007 | Samsung YP-U1 MP3 Player
RCA RP8078 5-Disc CD Changer Logo
200 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
