Question about Vtech IA5854 5.8 GHz Cordless Phone
How do I delete all of the caller id calls from my phone?
CORDLESSGURU
  • 106 Answers
SOURCE: Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Posted on Feb 10, 2008
SOURCE: Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Posted on Mar 07, 2008
zappanut
  • 959 Answers
SOURCE: VTECH CORDLESS PHONE WITH CALLER ID
make sure the MUTE button is disengaged.
Posted on Nov 24, 2008
SOURCE: ID quit registering
I just unpluged the system and pluged it back in. Didn't loose any information and it started working again.
Posted on Dec 07, 2008
SOURCE: Uniden CXA15198 not showing caller id
uniden model dx18560 not showing caller id
Posted on Dec 13, 2008
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How do i delete previous calls from my call display
To open the caller ID list, press CALLER-ID/RIGHT (cursor-right on the circular cursor pad).
To open the redial list, press REDIAL/PAUSE.
Use cursor-up/down to select the desired entry and press MENU/SELECT. Select "DELETE ENTRY and press MENU/SELECT. In addition, in the caller ID list you will have the "DELETE ALL" option.
The above are from the "Using the Caller ID and Redial Lists" section of the manual (page 11 in my copy). If you need a manual, you can download one at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf
Sep 19, 2011 | Uniden DECT14803 Phone
How do you delete missed call message from vtech 6.0 phone
Open the caller ID screen and scroll through the recent calls. Hope this helps =]
Mar 01, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Describe your cidco cw99 caller id+ user manual Problem I want to delete old data, set all to 0 calls. I don't have a user manual ! Thanks.
Hi drkossvt,
The way to erase all calls on the cidco cw99 caller ID is to arrow into the caller ID list and hold the Delete button for about 6 seconds. The screen will display "- NO CALLS -"
Note: it does not matter which Caller ID entry you arrow to before you hold the Delete button. This also works if you are on the "- END OF LIST -" screen.
If you want to delete a single call, arrow to that call and press the Delete button twice.
Feb 12, 2011 | Home Security
NO MANUAL HOW DELETE CALLERS IN LOG ?
You can download the owners manual in PDF format from this link.
412CID 4 Line Telephone
To answer you question - From the owners manual:
Erasing Caller ID Records
In order to delete a specific Caller ID record in the log:
1. Using the [<] or [>] key, find the particular record you would like to delete..
2. Press the [ERASE] key. The LCD display will indicate that the record has been deleted.
3. You may erase all caller information records simultaneously by pressing [ERASE] from the summary
Call ID display.
Hope this Helps.
Sep 25, 2009 | Bell BE-412CID Corded Phone
How do I go from no to yes in deleting ID calls
try either the volume key or the caller id key or just hiting delete again.
Sep 22, 2008 | Uniden Cordless Phone
Caller ID
Yes, it deletes the messages.
Jul 07, 2008 | Uniden Cordless phone EXS9950
Caller I.D wont show...
try to copy all the contacts on a paper then delete all the ph book contacts and write them again make shure that when you write the phone number with the area code if its like that on your ph book
May 17, 2008 | Motorola Mobility RAZR V3
Caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Feb 01, 2008 | Uniden TRU9480 Cordless Telephone
Vtech IA5854 5.8 GHz Cordless Phone Logo
138 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
