Question about Sanyo DS31590 31" TV
Playstation 2 game system
I conected a playstation to my video 2 input everything is fine but its not in color,how can i fix this problem?
  • Anonymous Mar 05, 2009
    I have the same problem but do not understand the solution posted
  • 54 Answers
Check if you use PAL/NTSC mode then try to adjust it in compatible mode. Or use AUTO.
Posted on Apr 24, 2008
My playstation2 not showing display
Check the output wires that attach the system to your television. One of the colored input cords are for the video. Make sure all three wires are plugged in securely.
May 08, 2011 | Sony PlayStation 2 (PS2) Console
Playstation starts all fine, everything is plugged in right, I get nothing on the screen and the controllers aren't starting at all.
i ran across the same problem .
make sure the system is off (red light is on)
hold down the power button for 5-6 seconds until u hear a second beep
thats it your video settings are reset and you shud be able to choose your input and configure it from there
zamy
Sep 08, 2010 | Sony Playstation 3 (PS3) Console
The screen get freeze with multi colors dots on it
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 13, 2010 | Sony Playstation 3 (PS3) Console
My playstation 2 wont show any video or sound yet everything else seems to be working fine. How do I fix this problem?
hi have you tried a differnt channel such as AV2 or AV3? also try to unplug the cables at the back and replug them in, see if this helps?
Aug 04, 2009 | Sony PlayStation 2 (PS2) Console
Sound problems
USE THE OPTICAL CABLE ,,MAKE SURE YOU CHECK THE BOXES ON THE SETUP AUDIO PS3,, LIKE DTS,,DOLBY,,LIKE THAT
May 13, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't play read my games
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
May 06, 2009 | Sony PlayStation® 3 (80GB) Console
Everything works on my playstation but it wont play games or dvds
Clean the lense on the inside or clean discs maybe try sending it 2 SONY
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
Ps2
you should have a video lead with 3 plugs on it ??
red / white and yellow...
If you do not have audio input and video input, then will need a converter (converts your plugs in scart)
I assume you have scart sockets on your tv ??
Please rate this response - Thankyou
Sep 09, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2 Loading
have you tryed other games?
If other games work, then your disk is probably damaged try a disk cleaner solution.
Mar 17, 2008 | Sony PlayStation® 2 Console
PS2 Half Green/Half Black Screen on powerup
I have had this happened when the PS2 has heated up my TV's color was going nuts. The color needed for the different games is sometimes too much. Let the TV rest for a while, then the TV, game should be fine.
Jul 09, 2007 | Sony PlayStation 2 (PS2) Console
Sanyo DS31590 31" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
