Question about Metz 54 MZ-4 for Nikon TTL Flash
Metz 54MZ-4 no longer flashes.
Unit lights up but no flash
  • 216 Answers
SOURCE: Metz 60-4 flash takes much longer than normal for the ready light to come on to allow me to take another photo.
If I can help.
atdlee@netzero.com
Posted on Feb 19, 2008
lightingman
  • 22 Answers
SOURCE: Metz CL-4 recharging problem
After 10 years of non-usage the capacitors in you Metz unit have become deformed- this is a common problem with electrolytic capacitors. The weaksound you observed is the unit's oscillator circuitry trying to feed the deformed capacitors. The capicitor's function, by the way, is to store the high voltage energy and release it in one strong burst of light when the unit is triggered- without capacitors, the flash tube would glow like a neon sign.
The first precaution to take is to NOT attach this unit, electronically, to you digital camera, The trigger voltage may be too high which can seriously damage your camera;s circuitry to the extent that the camera will be rendered useless and beyond repair. This can especially hold true if the flash unit has been somehow damaged because of the unit being fired with deformed capacitors.. Do theses procedures and testing by way of the flash unit's open flash button.
Try this- Start off with fresh batteries and install them in the unit. Make sure the battery terminals are clean and free of dirt, dust, corrosion are residue from leaking old batteries. If they are dirty, clean them with denatured alchacol, an ink eraser or an emery board, depending on the amount of dirt or residue.
Switch the unit on and listen for the sound- if you don't hear anything, move the batteries around and listen again for the sound- it it is intermittent, clean the battery compartment again and make sure the springs are tensioned up.
Once the sound occurs, and the light come on- DO NOT FLASH THE UNIT FOR AT LEAST AN HOUR! THEN FLASH IT AND SEE OF YOU GET A STRONG BURST OF LIGHT. Then flash it a few more times and see of the recycling times seem normal. If the recycling time is too slow, leave the unit on for a while longer and test again. You may need to replace the batteries once again for ongoing use.
If the unit does not come on at all or if it continues to only deliver a weal flash, the capacitors are probably permanently damaged. You may have damaged the charging circuit by flashing the unit with deformed capacitors.
Repairs? Unless you are a qualified and well equipped electronics technician, it is best to stay out of the innards of electronic flash equipment. Although the battery voltage is low, it is stepped up to very high voltages (at least 300 to 400 VDC) within the unit. Theses voltages can cause sever burns, nerve damage and even death if you should come in contact with them- and in some units, even after the power is turned off.
At this point in time,repair of you unit may not be cost effective but if you can't get ti going with the aforementioned test procedures you should check with you local repair facility of the unit's distributor- they MAY have a reasonable repair plan.
I hope this helps. If you get the unit going- be sure to purchase a protector that fits on the hot shoe of you DSLR to protect its circuitry when using older flash equipment. If you use manual mode on you camera or the auto flash feature on your unit- it should work perfectly well with your DSLR, Be sure to observe the camera's manual as to correct shutter speeds for proper synch. There may be a method for TTL operation with your camera- check it out with the manual and with the distributers as well. Make sure, again, tha there is no damage potential
Ed
Posted on Nov 12, 2008
  • 216 Answers
SOURCE: Metz Flash Power?
Hi Tom,
The battery is Metz Accu 60-38 4.5Ah at 6VDC
VRLA Battery 100 20 4010
Any Pb battery at 4.5Ah or higher will do.
Toy & Us sells some of them for kid cars.
eltroman
atdlee@netzero.com
Posted on Jan 08, 2009
  • 7 Answers
SOURCE: Metz 58 AF with Nikon d90 wont flash
If you hear rattling or a grinding sound/feel .. can be flash tubes broken.
Posted on Jul 21, 2009
ChiWai
  • 6 Answers
SOURCE: Metz 45 CT 1
I had that same problem also, but mines was temporarly. Ik think the condensor inside the Metz has to regeneratie (recover) itself by using with a full charged fresh batteries. The high freq. sound is normal. (although not to loud) after a 5 MINUTES the orange bulb should light up. How more u used how better the start-up time. My old Metz start-up time was around 40 sec. and now ot is within 7 sec.
Posted on Jul 25, 2009
Have to manually reset constantly the Metz 76 MZ-5 with SCA 3202 unit.
ya you can try the Metz p76 battery pack this will overcome the problem
May 16, 2008 | Metz mecablitz 76 MZ-5 TTL Flash
Metz 15 MS1 Macro Ring Flash with Panasonic Lumix G1 4/3rd Camera
Set camera to manual exposure. Set Shutter below 60 Set F Stop until exposure is correct.
atdlee@netzero.com
Feb 08, 2010 | Metz 15 MS1 DIGITAL MACROFLASH TTL Ring...
Metz 3201 hot shoe broken
Maybe its just me.. replace the shoe? Just get another SCA3201.
Jul 06, 2009 | Metz 54MZ-4 TTL Flash
Some info about batteries.. I've successfully used both NiCd and NiMH batteries loose in the alkaline holder, and in rebuilt old NiCd battery packs, in my 45CL-4. There doesn't seem to be any difference in performance or recycle time with either type of battery, but NiMH give more flashes, as they are higher capacity. The normal Metz charger is ok for NiCds, but isn't the best for NiMH, which need to be charged by a peak-detection charger. When NiCd and NiMH batteries are fully charged, their voltage reaches a peak, then drops slightly, The charger detects this drop and turns off. NiCd can stand some overcharge, but NiMH will be damaged if overcharged or overheated. I charge NiMH when taken out of the alkaline holder, in a special charger designed for NiMH. In the rebuilt packs, I charge NiMH directly onto the battery contacts, which is the top when it's in the flash gun. I use a piece of circuit board with two 3mm screws to reach the contacts, connected to a NiMH charger, and a rubber band to hold it on. It sounds funny, but it works well. I recently did a wedding and used only one 900mAh NiCd pack and one 2500mAh NiMH pack, for over 2000 shots. I used the Metz 45CL-4 on a Canon 40D.
Nov 10, 2008 | Metz mecablitz 45 CL-4 TTL Flash
Flash for canon 400d
Hi, This is Rakesh K Mewati from New Delhi, I have just want to know we have Canon 400D but still problem of Flash so which flash used in these camera please explain on that. Thanks Rakesh My E mail ID is rk.mewati@partner.samsung.com
Dec 13, 2007 | Vivitar 285HV Flash
Help
I hope that you've said the wrong model.
The right model is DSC-R1 with 24-120 Carl Zeiss' Japan.
Buy the Metz 54MZ with adapter for Minolta/Sony.
atdlee@netzero.com
Nov 13, 2007 | Vivitar 840AF AutoFocus Zoom Electronic...
It is likely the capacitor in the battery pack. If they are not powered up every month, they dry out resulting in long power up and recycle times. You'll need to get it replaced to rejuvenate your 60 CT-4 to its original spec.
Oct 06, 2006 | Metz 60CT-1 Flash
Nikon D70
Many electronics for analog (film) cameras will not work with digital. It is a huge frustration for me. See http://www.metz.de/en/photo_electronics/adapter.143.html -- You may have acceptable performance if you put the flash in "A" mode....Dave
Sep 20, 2006 | Metz 54MZ-4 TTL Flash
External Flash for 3000Z
I have tried a couple of external flashes on the 3000Z. It is my understanding from reading various Internet posts (and I am sure someone will correct me if I am wrong) that, other than triggering the flash to go off, there is no communication between the external flash in the hot shoe of the 3000Z and the 3000Z itself. Settings need to be made manually in the manual mode to set the f-stop and the aperture to get good exposures. The Metz flashes are expensive. Most have opted to use less expensive flashes such as the Vivitar 283/383, or a Sunpak, or even a "Wal-mart" flash. I chose an inexpensive bounce flash with a secondary "fill-in" flash to get rid of the shadows sometimes seen with indoor bounce flash pics. I purchased the Phoenix 82ZBDA Multi-dedicated twin flash from Porter's Photo Catalogue for $37.95. This flash works fine, but is not that powerful (GN 79 ). If you need a more powerful flash, you might consider the Vivitar 383.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Metz 54 MZ-4 for Nikon TTL Flash Logo
65 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
