Question about Philips 32PT6441/37 32" TV
Tv Won't come on green light blinks
Tv won't come on green on light blinks, checked resister on crt board, checked for cold solder joints.
  • 1 more comment
  • Anonymous May 29, 2008
    i have the same problom... i did get it to turn on with sound but then it shut off again
  • Anonymous Jul 03, 2008
    Green light on front of TV comes on but no sound and no picture. The green light will blink.
  • hezrhodn Jul 20, 2008
    tv shut off, green light blinks once long, then 5 quick, repeats, tv doesn't come on, if power is pressed, makes fast clicking noise...
All we had to do was unplug the TV and turn it back on after about 10 seconds. See if that works for you.
Posted on Jul 24, 2008
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
SOME TIME DOESNT TURN ON
remove the rear cover, then tried with re soldering cold solder or dry joints at the main board. if can not re solved with re soldering, check with an open resistance or change value resistor at the power supply circuit and at the horizontal section.
Jul 20, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv won't turn on and the light is blinking 7 times
Hello
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Check the power supply section for any loose solderings. Resolder all suspected solder points by applying a little more solder, without making a solder bridge short in between close solder terminals. OK.
Oct 21, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Television was alright when it was cut off. Next morning cut it on and the picture is all yellow and blue.
Tv is missing a color green,recheck ur tv Ant.hole coaxial cable input.Take the cable apart and reconnect to the Ant.hole again see if this help?Not make a fist with ur hand bang on the tv back cover frame see if the color green come back or flashes?Yes,than the tv CRT video board that is connected to the CRT- picture tube have cold soldering joints around it video board connections sockets,require resoldering the socket joints connections between the CRT video board and CRT tube connections socket.U have tools like a soldering iron,a roll of solders and can do basic soldering work?Yes,this problems just require resoldering that it.
Jun 10, 2011 | Sansui DTV3200 32" TV
My tv will not turn on i woke up this morning wanting to watch tv and it keeps making this funny noise everytime i try and turn it on I've had this tv for about 6 or 7 years what can i do? And usually when...
May be power supply failure and then maybe cold solder joints...a lot of sanyo's came in the shop that had bad solder joints...we would look for solder joints with a cracked looking ring around them , resolder them, and the set would usually work...you can try to remove the back to gain access to the underside of the board to see if this may be the case...otherwise, it may be a circuit malfunction
Jan 08, 2011 | Sanyo DS24424 24" TV
JVC TV
On projection TV's there are three tubes red,blue and green. It sounds like the green driver transistor is open. Check for loose connections or cold solder joints on the crt board at the back of the green tube.
Apr 07, 2008 | JVC AV32F476 32" TV
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
Toshiba 35
turn the tv off ,disconnect from power source , then you can
wait 1 hour appx. ,for the crt to discharge it self ,or you can
being very  carefull discharge the crt by inserting a long
screw driver under the ground strap that runs across the crt
(thats the metallic one ) the other screw driver under the anode
high voltage cap (thats the one that connects to the top center
of the crt) then short the two screw drivers together ,you should
see a little spark if there was any voltage there ,after that you
can solder  all the cold solder joints.
May I suggest that you check the main chassis also for cold solder joints.
I have checked many a TV.,and I always check the main chassis  to prevent callbacks.
BE SURE  NOT TO CREATE SHORTS WHEN YOU SOLDER
USE A 40 WATT SOLDERING PENSIL/IRON
TAKE YOUR TIME. YOU SHOULD HAVE NO PROBLEM.
Oct 23, 2007 | Toshiba 35A44 35" TV
SANYO 37 INCH TV
Check for cold or crystalized solder joints on the board that is connected to the CRT.
I would also check the solder joints around the high power resistors near or around the horizontal section.
Good Luck.
Oct 13, 2007 | Sanyo AVM-3659S 36" TV
Philips 32PT6441/37 32" TV Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
