Hi My washing machine Whirlpool AWM 5070 is not working after 2 loads of wash accidentally using soap powder without front loading labelled. Now, when it is turned on the dialled/ set for control ( far right knob) rotates automatically from the number dialled to stop without the machine even starting. Please help as soon as possible. Thanks.
    Brigadier General:
  • 3,917 Answers
Hi
The control knob is a common problem for this washer.
Get it off and look at the teeth. To remove the knob you need a pair of surgical pliers. Reach behind the knob and yank the retaining clip out. If the teeth are smooth you need to replace the knob. Oil the timer so it will be easier to turn by the way. To put the new knob you simply slide it in place with the clip on it.
Sometimes a bad timer will cause the machine to not advance from one part of a cycle to another. The timer is located behind the control knob on the console. Unscrew the knob by turning counter-clockwise and gently pulling it off. Open the rear access panel (on the back on the console) and disconnect the wires leading to the timer. Remove the screws that hold the timer in place. Install the new timer.
Please check the bellow link …
http://www.washingmachineadvisor.com/washing-machine-timer.html
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm/printable
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 13, 2010
Water coming out of soap tray and running down the front of the machine
Your soap tray and/or inlet is probably blocked with undissolved powder. Remove the tray and clean it. Also clean the inlet tube from the tray into the washing machine with hot water.
I, personally don't like soap powder and use a liquid or tablets because washers nowadays tend to use cold water only so doesn't fully dissolve the powder. Also the outlet to drain gets blocked along with the underground pipe to the mains sewage.
Sep 25, 2015 | Whirlpool Duet GHW9150P Front Load Washer
I have been given a Whirlpool AWM 312 by friends moving overseas and don't know how to operate it and would like to get a manual. My main problem is what drawer (front the left facing the machine) do I...
The manuals for most Whirlpool appliances are available here: http://www.whirlpool.com/custserv/index.jsp . Look for the full model number under the lid on the rim of the washer. AWM 312 is not a complete model number. Next is the washer a top loading or front loading machine? This is actually indicated in the model number - most Whirlpool models start WFW (front-load) or WTW (top-load). The exception is the compact washers (LCE4332PQ is the current model).
For the front-loading washers, the detergent goes into the largest compartment (usually the left-most part of the drawer). Top-loading washers that have a detergent compartment usually have it positioned at the top center back of the tub. Use HE detergent for high efficiency washers and do not use more detergent than recommended (using less is okay).
I hope this helps.
Mar 03, 2011 | Washing Machines
Its a stale, manky smell on all the clothes when they come out.
Hi, You did not mention front or top loading machine so I am going to assume you have a front loading machine.
Do this to clean your machine. Run a hot wash with 1/4 cup NON-bleach "powdered dishwashing soap" (Dawn or Cascade) and 1 cup of bleach. Then run a rinse with 2 cups vinegar and finally a regular wash with cleaning rags and HE type laundry soap. You may hae to do the dishwashing powder and 1 cup bleach wash 2 times to clear a bad case of mildew build up. You will not find this in any manufacturers user's manual but it will rid your machine of the nasty / musty smells.
If you are using regular laundry soap this problem will repeat often. If your using HE laundry soap you should do the above procedure about every 90 days.
We would appreciate hearing any success or failures related to your post by a future response from you as to how the solution above worked out.
Thanks for choosing FixYa,
Kelly
Jan 11, 2011 | Washing Machines
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
I have whirlpool AWM 243-500 washing machine, but it does not dry the clothes, I get my clothes with a lot of soap and water. Please help me. Can I get it manual, as I have any manual to know how to use it...
Hi mate what i think you should do is claen out the filter compartment at the front as it sounds that it is not rinsing properly.
Let me know how you get on.....
Feb 26, 2009 | Whirlpool AWM5125/1 Front Load Washer
Soap not being used
We learned from our new Duet that when washing with Tide soap powder, there is an adjustment inside the pull out drawer where the soap powder goes. You will see a grey plastic slider that goes to the right for liquid soap & to the left for powder soap.
Moving this slider to the left corrected this problem - not using all of the soap powder needed - for us.
Good luck !
Marilyn in FL
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine Model AWM 5104/5
the despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Feb 25, 2008 | Whirlpool AWM5104/1 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
