Question about Autodesk AutoCAD Freestyle
My 1997 Camaro Z28 doesn't get fuel to the injectors
My 1997 Camaro Z28 won't start after I changed the fuel pump and fuel filter. I checked the valve on the fuel rail but no pressure or fuel in it. What else asm I missing?
  • 491 Answers
Make sure voltage is getting to the pump,and every thing is tight
Posted on Oct 08, 2010
Car won't start
So then the next questions are - - do you have spark to the plugs and power and pulse ground to the injectors ?
Feb 01, 2013 | Cars & Trucks
Need fuse diagram for 1996 camaro ss fuel pump
This is for Z28--5.7L engine. I'd have to check voltage and ground for the fuel pump. At the fuel pump connector, gray wire is voltage, black is ground, check them both. Sometimes fuel pump will run but won't make good pressure, if any? You could jump load side of relay to see if pump will run and make proper pressure. The load side is that arm with arrowhead.
Engine cranking, you have spark at the plugs and fuel injector pulse, just trying to see if you have more than one problem?
Aug 23, 2017 | 1996 Chevrolet Camaro
I have a 91 camaro just got the fuel pump change n fuel filter also cleaned out the injectors in still won't start up full turn n my dash board wus workin just fine now its not working just got a new...
ask a local mechanic to have a look ,you may have left a power supply cable off from the positive terminal ,as for the non start then check for a spark and if a spark then check the fuel pressure it should be 55lbs on the injector rail is a tyre valve looking connection check the fuel pressure here
Apr 28, 2012 | 1991 Chevrolet Camaro
Twhy wont my 1995 z28 camaro start first time whenthe motor is cold
NOT GETTING ENOUGH FUEL OR SPARK.I WOULD CHANGE SPARK PLUGS AND WIRES.REPLACE FUEL FILTER AND CLEAN FUEL INJECTORS CHANGE AIR FILTER.SOME TIMES A LITTLE TUNE UP WILL HELP COLD START PROBLEMS.
Dec 08, 2010 | 1995 Chevrolet Camaro
Dodge cummins won't start, fuel reaching injector pump but no fuel coming out of injector pump.
You said you have fuel flowing from the inlet line of the injection pump? But not at the injector lines?
May 05, 2009 | 1999 Dodge Ram
Lack of Fuel
Just because the fuel pump is on does not mean it is delivering the proper pressure. Some systems need as much as 35 psi to function properly. I would look there. I am assuming that you have checked the pressure as you had mentioned that the "Injectors have a lack of pressure" in your statement. Some of the old chevys used to use a "Sock" type filter on the pick up tube in the fuel tank. A possibility? Could be partially clogged. Good Luck
Feb 16, 2009 | 1990 Chevrolet Camaro
My 94 z28 camaro chuggs when i punch it
sounds like a fuel pump struggling to pass its contents. try running a treatment solution in your tank. if this fails to work, you will need a new fuel pump to correct this problem. sometimes, trash will build up in your tank and it will cause build up in the jets. you should check vacuum as well if needed.
Jan 28, 2009 | 1994 Chevrolet Camaro
1997 Camaro, Z28 Car is running rich, flooding out and fouling
any codes come up? try to take it to any auto parts store napa autozone or advance auto they will hook up a obd 2 code reader for free and that should help you narrow it down. If i had to guess it would be one of the o2 sensors?
Jan 20, 2009 | 1997 Chevrolet Camaro
Autodesk AutoCAD Freestyle Logo
140 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
