Question about Toshiba TLPLV5 Projector Lamp for TDP-S25
Toshiba TDP-S25 Projector
My projector turns on with all lights green, but then the green lights go out and the red Fan light comes on
Marrie
  • 563 Answers
SOURCE: focusing
Hi real12
Unfortunately you will have get the focus ring replaced before you will be to make use of it if your model doesn't have automatic zoom and focus in the user menu.
Sorry , but there simply is no other way.
Posted on May 21, 2008
Marrie
  • 563 Answers
SOURCE: Toshiba projector switching itself off
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
SOURCE: Toshiba TDP-T90 projector, lamp
I have the same problem. The lamp cover has a tab that sticks up about 1/2 inch. When you close the lamp cover the tab presses on a wire that allows power to the lamp. You can hear a 'click' as you close the cover slowly. My tab kept bending over preventing it from depressing the wire. I've straightened it several times to where now it broke off to where it wouldn't work at all.
I fixed the problem by clipping off the tab, inserting it in the bulb case to press the wire and taped the tab in place.
Posted on Dec 02, 2008
  • 320 Answers
SOURCE: Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Posted on Mar 06, 2009
projdoc
  • 2237 Answers
SOURCE: I have a Toshiba TDP ET20 projector, the problem
if the fans come on but no lights, listen for a high-pitched whir. if you don't hear it, the colorwheel needs to be replaced. if you do hear it, replace the ballast. if no fans, replace the power supply.
Posted on Nov 11, 2009
We have Toshiba TDP-T05 projector - recently replaced the buld - projector starts then does not work red indicator on Fan and on button - looks like Fan bad. Can this be fixed or better to buy new.
Before going to by a new one just try to do the following
First of all try to reset the lamp hour of your projector. For resetting the lamp hour do the following.
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on,
Otherwise Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projecto and watch.
ok
Mar 07, 2011 | Toshiba TDP-T95U Multimedia Projector
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
Replaced bulb in projector and it still doesn't
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Jan 05, 2010 | Toshiba TDP P4 Multimedia Projector
I have a Toshiba TDP ET20 projector, the problem is that there is that it wont power up. There is a click when the power is turned on but no lights, including the main projector light, come on
Nov 06, 2009 | Toshiba TDP-ET20 DLP Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
Focusing
Hi real12
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
Toshiba TLPLV5 Projector Lamp for TDP-S25 Logo
98 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
