Question about Sony Televison & Video
TV TURNS ITSELF OFF AND AFTER A FEW MINUTES WILL COME BACK ON. IS THIS A TV PROBLEM OR A CABLE PROBLEM
    Guru:
  • 416 Answers
I assume this is an LCD or SxRD projection TV... you need a lamp. The lamp's burner is worn from use and when it becomes hot, expansion occurs and the lamp extinguishes. The TV will attempt to reignite the lamp 3 times after it goes out. If successful, it will continue to operate until the burner expanded too far once again. This will repeat over and over. Eventually, the lamp will not come back on. Order a lamp and replace it. Best wishes, I hope this was helpful.
Posted on Jul 13, 2010
3 Suggested Answers
  • 22 Answers
SOURCE: TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Posted on Nov 13, 2007
localwonder
  • 6784 Answers
SOURCE: My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Posted on Jul 21, 2009
Why is my 2011 Sharp Aquos TV crashing?
Sharp Aquos "crashing" - HDTV - Streaming Video & TVs - Tom's Guide
www.tomsguide.com/forum/24705-4-sharp-aquos-crashing
Aug 11, 2005 - 7 posts - ‎1 author Archived from groups: alt.tv.tech.hdtv (More info?) I have a Sharp Aquos 37" LCD TV(37GD6U). Every now and then I can turn it on,
Oct 20, 2015 | Sharp Televison & Video
Sony 42we655 turns off by then back on after a few minutes
It could be a sign the lamp is nearing the end of its 2000 hour life--another indication is when it turns off do you get blinking lights on front of set or not?
May 29, 2012 | Sony KDF-42WE655 Television
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
