Question about Lexmark C920 Led Printer
How to reset Fuser Replacement 80 on C920 Lexmark - new fuser hasn't reset the warning
    Genius:
  • 1,087 Answers
Go to Configuration by pressing the Check button the right arrow button while powering up the printer. Then choose reset fuser count. Hope this helps.
Posted on Jul 13, 2010
How to reset Lexmark t650 fuser unit?
Fuser's don't have a 'reset'.....they just get hot and melt the Toner onto the paper.
I think you mean "how to reset the maintenamce counter".
Go to this page and watch this video for replacing the Fuser Kit on your model printer.
Lexmark T650 T652 T654 Fuser Maintenance Kit Replacement and How to...
Oct 13, 2014 | Computers & Internet
Hello, I replaced the fuser on my 734de and I still get fuser life warning
Did you replace the fuser with a new Lexmark fuser or a refurbished unit? The original Lexmark units have a chip in them that resets the counter when installed. However this only works the first time the fuser is installed. If you install a used fuser in a different printer it will not reset the counter.
Sep 30, 2014 | Lexmark Office Equipment & Supplies
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
Lexmark t-620 print spots
That usually indicates a worn heat roller in the fuser assembly. You can get a fuser from Amazon or other online site. They are user replaceable and run about $80-100. Do a search for T620 fuser and you will find them. Part number 99a2402 What happens is the Teflon coating on the fuser wears down which allows the toner to stick where is should not stick so it gets deposited on the paper in other locations and leaves spots.
Apr 18, 2013 | Lexmark Office Equipment & Supplies
When you turn on the printer, the code 80, code appears to want to reset the wrong network
code 80 is maintanance message askinfg for the fuser charge and transfer roller to be changed. to reset counter hold tick and right arrow will go into config menu you can then reset counter. but if you do not change parts it will start to jam due to fuser at end of life
Aug 15, 2011 | Lexmark T644 Laser Printer
I replaced the fuser unit on a lexmark c534dn but i still receive the "80 fuser unit in exau" message
You'll need to reset the maintenance count on the printer. The instructions to doing this are usually provided with the replacement fuser. But the method is usually the same for most printers. Turn the printer off hold the go and return or select and return buttons while the printer is starting up until the display reads Performing self test then release the buttons. This will take you to a configuration menu were you should be able to find a reset fuser or reset maintenance option.
Mar 03, 2011 | Office Equipment & Supplies
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
I have a c920 lexmark with a fault code 920.000. my guess is that the fuserisnt heating up... based on the fact that its not getting hot... im guessing the fuser lamp has blown.... is there any other...
Hi, Majorly this Error 920.X display for a cold fuser. Some 920.xx error codes may be cleared by turning the printer on and off.
In general, fuser errors require replacement of the fuser. Fuser errors can be from a cold fuser or an overheated fuser. In your case you need to replace the Fuser.
Feb 22, 2010 | Lexmark C920 Led Printer
Clear fuser life warning C524
Replacing the fuser
When 80 Fuser life warning appears on the operator panel, replace the fuser soon. Make sure one is on order. See
Ordering a fuser for more information.
When 80 Replace Fuser appears on the operator panel, replace the fuser immediately.
......From the Lexmark users guide.....
Dec 23, 2009 | Lexmark C524 Laser Printer
2,239 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
