Question about Mag Innovision M572TVs LCD Television
NO SOUND ON MY maG TV - Mag Innovision M572TVs LCD Television
My tv wont come on the green light comes on for a few sec then the red light comes on blinking i have a mag flat screen model num 50mf231d137
your high tension transformer is defect.
replace transformator flyback and transistor BU508AF or equal
Nov 19, 2013 | Philips 27PT543S 27" TV
How too hook up
HDMI cable from Mag to TV (to be able to use up-scaling) or component cable (observe colors!) from Mag out to TV in. In addition audio cable from Mag audio out to TV audio in and composite video out to video in on the TV.
Jul 04, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have just the sound
If this is an LCD TV, show a flashlight on the screen from a safe distance. If you can see the picture, the TV needs servicing.
Aug 21, 2012 | Mag Innovision Televison & Video
I have a MAG 26"
HELLO,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope that will help in solving the problem.....
Feb 01, 2011 | Mag Innovision Televison & Video
Mag TV Model 3200 MA-32EF1AC Tv will power on but no picture or sound. The very last time it 'worked' there was sound but no picture. Then picture but no sound. Now, nothing. Am I out of luck?
Yes you are. The power board is out - the section that distributes voltage to the audio and video circuits. Take it to a TV repair shop but first check the price of a new set like the one you have. Get an estimate from the shop - if it exceeds the price of a new TV then it's not worth fixing.
Nov 02, 2010 | Televison & Video
No sound from the monitor
Go to control panel and find volume sound and put the WAVE up on line.
Vitally
Jun 02, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Maganavox TV Troubles
Im just gonna guess your TV is a Mag 230 or 230 Your problem is goning to be a defective Y-main and upper and lower Y-buffers.
Get back in touch and ill find the part numbers for ya.
Apr 14, 2008 | Televison & Video
No sound on mag monitor
well,maybe the speaker of your monitor is damages..and need for check-up and diagnose..
Jan 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision M572TVs LCD Television Logo
283 people viewed this question
Top Mag Innovision Televison & Video Experts
jason
Tom Chichester
Are you a Mag Innovision Televison and Video Expert? Answer questions, earn points and help others
