Question about Whirlpool Refrigerators
Hi, I have a Whirlpool fridge/frezzer, model WRN38*WG6, its about 8 years old but until recently has worked perfectly. There is some water dripping from the grid under the freezer into the main part of the fridge. I changed the temp to be the coldest but this only made the food in the fridge freeze! so I've put it back to half way in between. Any ideas on what might be causing it?
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
  • 306 Answers
SOURCE: Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Posted on Nov 26, 2008
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
  • 175 Answers
SOURCE: The freezer section is working ok but the fridge
hi..you may have a coolant leak and need it repaired
and recharged.
check this out..
thank u..
kindly rate my response..
Posted on Jun 14, 2009
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
I have an all fridge model with water accumulating under the vegetable/crisper bins. Like other I have read about here, I have to sop up the water at least twice a day. I have had this refrigerator for...
I have also had a similar problem with twi different fridges. The first I fixed by unblocking a tube that runs out of the back to a tray underneath where the water goes and evaporates naturally, this was a very old fridge. The second was because of the door seal. I replaced it and it was better but not perfect. I then realigned the door, which seemed to cure the problem. I sold the fridge a year ago, and the guy who bought it says it works fine.
Nov 30, 2017 | Whirlpool EL7ATRR Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Frezzer not frezzing
if you have a old refrigerator it is probaly dying this happened to my parrents fridge a couple years of ago so they got a newer frigde and it works good but if you by a fridge make sure you by name brands
Jun 23, 2008 | Refrigerators
Frezzer working fine, but fridge very warm what do i do
if the technician says you need a defrost heater, then it should be replace for the refigerator to work perfectly.
Jun 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
216 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
