Question about Hunter "Lexus" Traditional 52" Ceiling Fan "Black" w/ three Blade Choices
I have a ceiling fan with footprint vents, and I want to get a copy of one to put in the same room at different spot. I can't find the brand name and model number/name. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • AsshoIe Jul 14, 2010
    I found the brand name. It was litex.
  • 553 Answers
I want to help you but I'm not sure what you mean by "footprint vents", can you give me a little better idea?
Posted on Jul 13, 2010
  • 3 more comments
  • AsshoIe Jul 13, 2010
    The vents with footprint shapes on. It is like the one in youtube video called "foot print vent fan."
  • jonesspammai Jul 13, 2010
    When you say vents do you mean the holes in the motor housing or do you mean the vanes or blades?
    holes in the motor. The circle part of footprints is facing toward the center.
    I've tried the wholesale electic supply houses that I have online accounts with but didn't find one. I'll see if I can find one when they open tomorrow.
    I'm sorry, I got hold of my contacts at the electrical supply houses and we didn't come up with a single fan that meets your description. We checked all the major brand catalogs and could only conclude it's either a discontinued design or was made by a custom supplier. I did come up with one possibility, an online company called: ceilingfanuniverse.com. They have over 2500 different ceiling fans including specialty fans. Good luck.
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
Hunter Ceiling fan remote is operating all the other ceiling fans as well
Sounds like all the dip switches are set to factory still. Easy enough to fix.
Slide open the battery compartment on the back of the remote control and remove the fan's canopy against the ceiling. Then just change the switch to a different setting but make sure that the remote and fan have the same setting. Repeat this in each room so that all the fans have a different setting to each other.
Hope this makes sense.
Aug 02, 2012 | Hunter 52" Ceiling Fan With Light And...
I just replaced my manual thermostat with a programmable one. The problem is the old one was positioned under a ceiling vent. Now the programmable one cause the heat to cut on and off before the room...
Move the wall thermostat to a new location away from the ceiling fan or stop using the ceiling fan. Also, try running the ceiling fan in reverse (counter clockwise when you're looking up at the fan blades) on slowest speed. That might solve the problem, too.
Please let e know is that helps.
Rich
Feb 07, 2011 | Heating & Cooling
Cannot stop the ceiling fan from wobbling. Have
you still have a blade that is out of balance. mesure each blade from the bottom side end to the celing in one spot. Do this for each blade when you find the one that is closest to the celing then you have to place the wheight on the edge of that blade then spin it to make the right adjustment then seta stick on weight where the temp. weight is at
Jul 31, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Takes the dryer over two hours to dry one load of laundry. It appears to be putting out hot air. When I stop it to check the clothes, the clothes are usually really warm yet still wet. This has been going...
You have a venting problem. Some makes of condo size dryers have a lint screen inside the drum at the back. Check and clean. If not then there might be a screen in the wall or the ceiling of the room the dryer is in. Trace the vent from the dryer to the wall or ceiling. There should be a vent fan in the ceiling. Try asking the condo property management if there is an exhaust fan in the wall that needs cleaning.
Jun 21, 2009 | Dryers
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
Fixing Ceiling Fan
An easy-to-install ceiling fan can make a real difference in your home's climate - both cooling and heating - at a far lower cost and operating expense than almost any other item.
The installation begins with choosing where the fan should be located. In almost all homes, the fan is installed in the center of the room, replacing a central light fixture. This spot provides a smooth air flow to most of the room. Since a fan draws about the same power as a ceiling fixture, the electrical circuit shouldn't be overloaded. But if your fan includes lights, be sure the circuit it's on has enough extra capacity to handle the load. If not, you must run a new circuit with a new circuit breaker from the house main service panel or subpanel to the fan. If there is no central light fixture, you'll have to create a place to hang the ceiling fan. Then, you'll need to bring electrical power to it. You can tap into an existing circuit to do this.
Sep 25, 2008 | Dryers
Hunter "Lexus" Traditional 52" Ceiling Fan "Black" w/ three Blade Choices Logo
44 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
