Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Phillips magnavox 9p5540 c104 is not turning on it has a high pitch wine to it when powered on but no picture
  • 150 Answers
SOURCE: TV Projection filter screen
I would not use any kind of chemicals on the screens, I definitely would not use any liquids on anything besides the screen protector, the inside screen is a Fresnel lens and will wick up moisture, the one with the vertical grooves is the Lenticular and either one will leave a mark, if you have to use liqud, I would try distilled water, but no guarrantees you will get it clean. I usually end up replacing the screens. Looking at your post you said filter, do you mean an air filter? I dont think these sets us an air filter, if it was just dust a t-shirt or microfiber towel usually work, the towel being my choice.
Posted on Jul 08, 2007
  • 44 Answers
SOURCE: model # 9p5540 c104
Try adjusting the Brightness of your TV...
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Posted on Mar 28, 2008
Slinteriors
  • 8617 Answers
SOURCE: Double picture
Youre convergence Ics need to be replaced. Use STK392-120 Ics you will need to replace both of them. You can get replacements at the following link and they provide free instalation instructions with pics.
http://servicemanuals.vstore.ca/
Posted on Jun 15, 2008
SOURCE: Magnavox E10839 has no picture and a high pitch
that seems to be an issue with your color wheel, it's starting to go out, beofre you replace it you need to verify if you have a gol or silver bearing, because if you don't get the right one, it will not work on your tv, since they have a different mechanism, but just make sure whihc one it is and you'll be fine :)
Posted on Jul 16, 2009
  • 178 Answers
SOURCE: picture is going out
it is either ic 7411,7412, 7413 they are cheap replace all three, they are located on the back of the large signal panel right in the middle, very common issue. If you can't solder the repair may cost around 200 or so .
Posted on Sep 02, 2009
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Hi: My Magnavox flat screen turns on and off. It also makes a high pitch noise and then there is no sound and it also shuts off. Is it worth fixing?
Hello, what's the model or size of screen for the magnavox, the high pitch noise could be an audio power amp starting to get intermittent, and the power on/off could be due to the over current sensor circuit detecting the audio problem. Depending on the model number you would have a seperate power, audio and signal board in the TV. If he TV is 27" or smaller all these circuits are part of a mother board.
Jul 28, 2010 | Televison & Video
When I turn it on the screen stays blank and there
this a defective power supply, normaly the HV circuit is burned, needs to be repaired. send to repair shop
Jan 29, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P5040 C104. Green power light- no sound/ no picture, fuse good.
Hey my tv is doing the same thing. The green power light with no sound and no picture and the fuse is good. I was wondering if you fixed the problem and if you could tell me how to fix mine.
Nov 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
97 f-150 high pitched wine from radio, buzzing behind instruments
If the whine changes pitch with engine RPM it could be a serious problem with the alternator. Possibly the voltage regulator, or a shorted diode in the alternator causing high frequency AC to be fed into the harness.
Oct 09, 2009 | 1997 Ford F150 Regular Cab
Picture is going out
Sep 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
High Pitch squeal everytime t.v. is turned on. 20min warm-up.
sounds like the switchmode power supply is varrying in frequency ..needs to be checked by qualified tech,,,
Apr 16, 2009 | SNK Magnavox 19MF338B/27 19 in. LCD TV
Double picture
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Model # 9p5540 c104
Thanks and Regards
Mar 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
