Question about Fiesta Advantis 1000 Grill
Gas tank is full, burners are turned on high, but flame is very low
  • 8,220 Answers
LProblem: Low flames on grill, tank is full.
Cause: These newertanks have a device inside that limits the flow of gas to preventleaking or accidental discharge of gas from the cylinder. The leak detector mechanism inside the tank shuts off the gas whenever the valve is opened rapidly.
Solution:
Closethe tank valve and remove the tank. Check the gas line for ANY objectthat could cause blockage. Open all valves on the grill to eliminateany pressure whatsoever. Close all valves and reattach tank. SLOWLYopen the tank not over 2 turns. Check for leaks. I just open my tank atiny bit but that is just me.
This late model gas grill service manual has more details on page 13
Posted on Jul 14, 2010
    Champion:
  • 274 Answers
Try replacing the regulator and hose, easy to do and inexpensive.
Posted on Jul 13, 2010
I just turned on my gas grill and lit the burners and it started humming. what's going on? Is it safe?
Sue, it's not really that dangerous, but you need to correct the problem.
It's generally caused by a change in the gas pressure. Turn the Tank Valve OFF and Disconnect the hose from the tank. Lift the tank out of it's holder, to determine by it's weight, whether low on gas or not. If you determine that it is low on gas, stop using the tank and have it refilled.Or switch to a full tank, if you have a spare.
If you determined there is adequate gas, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.(Which you have already
done).
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct and the humming has
stopped? If so, you solved the problem. Remember, to always open the tank valve Very, Very
Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 12, 2011 | Weber Genesis Silver B Grill
Low gas pressure even with fresh tanks.Could the regulator be the problem?
Yes, the regulator is the problem, but not exactly the way you may think.
To solve the problem, turn OFF the tank valve and disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Now, unlike how you turned the fresh tank ON, this time turn it ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is full open, light the burner farthest away from the tank first and turn it to HIGH. Has the flame height returned to normal? If so, light the remaining burners the same way. Do all the flame heights on High, look correct. If so, you solved the problem. If not, repeat the full procedure over again.
If after the second attempt, the flame heights are still low, you'll need to replace the grill's hose/regulator assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. Take your old one with you for comparison purposes.
Hope this helped you solve the problem and Happy Easter!
Apr 24, 2011 | Crown Verity MCB-36 (LP) Grill
I replaced the burners under the grill and the gas is is flowing with a very small flame but i cant get it to have a large flame. what can i do?
Easy solution. Turn off your propane grill tank. Disconnect the hose from the tank, Wait 5 minutes and reconnect the hose. Now, turn the tank vale on very, very slowly, until it full open. Then light each burner one at a time. Turn the flames to high.The burner flame height should have returned to normal.
Remember to turn the tank on very, very slowly each time after turning the tank off.
Happy Grilling!
Feb 11, 2011 | Ducane 30400040 Stainless Steel Grill
Low flame
close the air vents to the burners
Jul 05, 2010 | Weber Genesis Silver B Grill
I have a full propane tank. I bbq'd about 3 weeks ago, same full bottle. Grill will not light. Good spark at ignitor. Used lighter and lit for a few seconds with low flame on high. No other burners will...
You may have turned the gas tank valve on too fast. Turn it back off, disconnect it and reconnect it. Then very slowly turn the valve back on. Light one burner at a time and turn to low before lighting the next. If you are hearing and smelling gas with the tank on but all grill knobs off, don't use the grill. You may have a leaking grill valve, regulator or hose. If you are only smelling gas with the knobs on, it's possible you have a clogged burner or orifice from bug nests, spiderwebs, etc and need to clean it out first. Hope this helps. Douglas
Jun 13, 2010 | Brinkmann Charmglow Stainless Steel LP...
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Fiesta Advantis 1000 Grill Logo
344 people viewed this question
Top Fiesta Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lawrence Oravetz
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
