Question about Sunbeam Food Mixers
MX8900w bowl rotator stalls and changes speed.
Mixer MX8900w bowl rotator stalls and changes speed.
  • rlsides Jul 13, 2010
    Already know it is a defect.
    Looking for more diagnostic help.
    I may just bypass the electronics on the small motor and let it run at constant speed. Seems the regulator or its settings are faulty. Seems to have been not working properly from new as it never altered its speed, was constant, and now is playing up. Will check warranty before doing anything serious.
  • 6,826 Answers
Twin-motor 3-way beating action
Patent pending twin-motor design enables one
motor to drive the beaters, each turning in
opposite directions. The second motor drives the
bowl, thus combined, this new technology results
in a more powerful and thorough mixing result.
Variable bowl speed
The bowl speed increases and decreases
automatically as the beater speed is increased
and decreased.
As I understand it the 'variable bowl speed' feature
is working correctly.
Your stalling condition can be caused by mixing dough
that is too thick for the machine's beaters to work with.
Bowl selector
Simply slide the bowl selector lever to the left
when using the small bowl and to the right when
using the large bowl.
The bowl selecter lever may be set to too small or large of a bowl.
Also, use the 'dough' hooks when kneeding dough.
Speed setting ranges from 1 through 10 through 12 for high.
Maybe the speed setting is too low for the mixing that you are doing.
For further information I enclosed the following link:
http://www.sunbeam.com.au/Pages/Support/ManualSearch.aspx
Input your model # to download the .pdf manual file.
Good luck in cooking with your Sunbeam MX8900w.
Posted on Jul 13, 2010
    The stalling problem and variability occur UNLOADED.
    The speed does not increase and decrease with the main motor speed it behaves the same no matter what the main drive speed is.
    Regards Roger
  • Duane Wong
    Duane Wong Jul 13, 2010
    OK, it sounds to me like it could be a manufacturing defect or it got damaged somehow
    internally.
    I would contact www.sunbeam.com for service to the unit:
    http://www.sunbeam.com/ServiceLocator.as...
How do I fix my Kitchen Aid Professional 5 mixer that will not change speeds?
The speed adjustment is defective. You will likely need a service centre if you cannot open it up and find the problem and change any defective parts etc.
Nov 24, 2014 | KitchenAid KP50PS Professional 5 Series...
Need a new bowl
Sadly FIXYA has no control or ability to FIX the problem you have with the mixing bowls you ordered that are not the correct configuration for your mixer. suggest you contact the manufacturer again
Aug 17, 2017 | Oster Stand Mixer model: Fpstsm5102
Sunbeam model mx8900w circuitboard not working wont start possibly need newone.
Hi Eschill,
The model you posted was 2370 and mx8900w ar enot the same. YOu may want to check the basic troubleshooting guide based on the model of your mixer. Just click this link MANUAL. Just message me if you have any question.
Aug 04, 2011 | Sunbeam 2370 MixMaster Series Stand Mixer
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
Sunbeam stand mixer's mixing bowl does not turn when mixer is on!
You may have a product failure. Yesterday's Sunbeam is not today's Sunbeam.
Dec 03, 2017 | Sunbeam 2353 Stand Mixer
I have a Sunbeam Heritage Series Mixmaster, 350 Watts, just purchased yesterday. I used it to mix cake batter, cream butter, whip egg whites....the problem is that it doesn't blend the ingredients. The...
There should be a small lever on the base in front of and below the bowl. It will move to 2 positions. It sounds like you have it set for the small bowl but are using the large bowl. Press down on the lever and move it to the other side. If I'm right, that should correct the problem.
Oct 26, 2009 | Sunbeam Heritage 2346 Stand Mixer
A200T Slips in low and medium speed
Planetary gears worn from, #1 changing speeds while unit running, #2 over loading the bowl. batter & icing max 75% bowl capacity, Dough max 65% bowl capacity
Jul 17, 2009 | Hobart A200 Stand Mixer
I have to physically hold my Artisan mixer in place or it will go off the counter, even at low speeds. Seems to rotate fine as long as the head isn't down with an attachment on and in the bowl.
I think from your description that the the head connecting to the base shaft needs tightening. Put the mixer on it's side. Look up inside the base and you'll see a small set screw.
With a flat blade screw driver tighten that screw and it should stop moving. If it doesn't you probably need another shaft because it's worn.
May 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
Jan 15, 2009 | Hobart D300 Stand Mixer
Food Mixers Logo
60 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
