Model DVDR3320V recorded from JVC DVD player thru AV3 using Sony R...initialized & finalized disc ok but when removed and then inserted can not get past *reading* message on Philips display..can open/close after turning off power..plays ok on JVC thru AV3..Thanks Geoff
  • gmcgoo21 Apr 20, 2008
    izzy2.. recorded +r dvd on philips from 2 seperate video cameras.1st 30mins then paused.connected 2nd v camera continued recording.can play 62mins on jvc thru av3 ok.when disc which has been initialized/finalized inserted in phillips will not let us past reading stage..works ok when jvc direct to tv's av2 disconnection of power does not reset looks like it is frozen.thanks
    second opinion required..thanks
  • 19,396 Answers
Well, I will ask no indulgence apart from Benimur here.
Experts should answer questions, not keep asking to get a placeholder in the thread.
Regarding the problem. Some reader can develope problems in readin/writing +R or -R dvd, even if they are supposed to support both.
The difference in this two format is error correction method. Many dvd work well only with dvd-R , other with DVD+R.
This is normally due to problem caused by electric noise in the laser pickup and wobbles introduced by the electric motor spinning the disc. The +R and -R technology had been developed to fix this problems.
+R have a far more efficient error correction, but -R are sometimes easier to read/write for some device, as they use an empty space between two tracks.
I won't enter in detail on burning +r,-r technologies here, just try using good brand -R dvds if you can, cheap DVD can also create troubles.
Posted on Apr 22, 2008
    Brigadier General:
  • 6,966 Answers
Hi gmcgoo21,
with the indulgence of issy2 and otacon...
If I understand your concern right, you have:
1. a JVC DVD Recorder/Player connected to your TV on AV3;
2. a Philips DVDR3320V DVD/VCR Recorder/Player connected to your TV on AV2; and
3. as issy2 has posted, your DVDR3320V is your main concern since recorded disc will only be read initially but not playable and will freeze thereafter. You have tried full hard reset by disconnecting the Philips from the mains for a couple of hours to try and revert it back to factory defaults. Alternately, you can try (with no disc inside but the Philips powered on) goto General Settings, Factory Set Option, Arrow Right to select Set, OK, Yes, OK. This is better explained in page 18 of the User's Manual.
Additionally, some users have reported a more stable performance of this DVD Recorder/VCR version of Philips with a firmware update
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 20, 2008
    President:
  • 1,944 Answers
Could you please descreibe your problem more in detail so we can help you? Thanks.
    Master:
    Sergeant:
  • 462 Answers
We will look into your problem and get back to you.
  • Mohamed Ismail
    Mohamed Ismail Apr 20, 2008
    Please can u be more clear with your problem instead of being short. Please ellaborate.
    Thankyou
  • Mohamed Ismail
    So u mean to say that u are having problem with the philiphs player.. am i right...?
Finalizing a DVD-R blank disc
try changeing the disk name and then see if the finalize option is availalbe.
Jun 18, 2008 | Sony RDR-GX315 DVD Recorder
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
Sony DCR DVD108 not finalizing disc, lost data
I noticed that too with my "VR" (and NOT "Video") formatted disks. I don't think you can finalize the VR ones. Instead you have to use the Sony Import tool to grab the videos. If you are like me you probably remember using the import tool with Video formatted disks BEFORE finalizing them and it takes forever to copy them. They must be finalized to view on other devices, copy using the import tool quicker, etc., but VR formatted disks seem optimized for importing (and can be edited on the camcorder directly.
Sep 26, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Finalizing
Use a name-brand DVD, such as HP, Verbatim, etc. and make sure it is a DVD+R or DVD-RW/-R disk only.
It is most likely that the DVD you are using is not compatible.
The disk is still usable, but you can only read it on that player.
Aug 17, 2009 | Funai PY90DG DVD Recorder
I recorded a dvd and it will not play in any other player.
You must finalize the DVD after recording it. If you post the model of the JVC device, I may be able to find out how to do this for you.
Jan 12, 2009 | JVC DR-MX1S DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
My JVC DR-MV7 will play most DVDs and even record, but recently, it stopped being able to finalize. After I get the message saying "finalization has failed," I can't even play the DVD anymore - thus losing...
My JVC DR-MV7 will not accept any disc for playback. I insert a movie disc and it consistently rejects them. After about 15 to 20 attempts, sometimes it will stay and begin reading the disc. It also sounds like some internal components are encountering some resistance (moving parts inside?). Any ideas?
Nov 27, 2008 | JVC DR-MV7 DVD Recorder/VCR
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
