Question about Maytag Atlantis MAV6000 Top Load Washer
Washer will not spin.
Recently has been squealing at various times during the wash cycle.
  • droether Jul 13, 2010
    The information provided was very helpful and I will be moving forward based on this advise.
  • 5,911 Answers
This is usually causes by a worn snubber assembly and/or brake assembly. The following link explains:
http://www.fixya.com/support/r3574320-maytag_washer_squeaking_problem
I have included part numbers for tools you may need and some advice on what you can do to avoid having to purchase any higher priced special tools.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number is correct, the part numbers for the recommended parts to replace are as follows:
Brake Rotor with Lining - 35-6714
Brake Stator - 35-6918
Snubber - 21002026
Prices will vary between the sites I have listed, so shop and compare. The first three sites I have listed, have helpful exploded view diagrams to assist you with locating and properly identfying the parts you need. If you search by model number, these parts are listed under the "Transmission" parts list. This is not a difficult repair, and the parts (including most of the tools) are not expensive.
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Posted on Jul 13, 2010
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
Not spinning
Sounds Like Its The Belt Open Up The Unit Get The Broken Belt And Take It To The Auto Parts Store And Have Them Give You One Of The Equal Length.
Jan 15, 2009 | GE WBSE2090A Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
259 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
