HP Pavillion dv6000 series -- laptop CD/DVD drive quit working recently - computer doe not recognize that I even have one (on computer list) ... one USB port not working Sound has not worked since the first year I had it -- sent it in to HP - they did not fix the sound ... Sometimes when I turn on the computer, I'll have sound for about a minute - then it's gone... Purchased computer 2 1/2 yrs ago Other than getting a new computer, any great ideas?
  • authormontan Jul 13, 2010
    I have 3X gone back to the original operating system and started over ... did not fix sound ... at that time the CD/DVD worked and so did the USB ports...
    WOuld like to see if there is another solution vs. a new laptop
  • 903 Answers
With that many different problems, it seems most likely to be a motherboard issue. The sound card, DVD drive, and USB ports all interface on the motherboard, so if the board suffered some kind of damage (electrical damage, shock damage, if the laptop was dropped or jostled) it could have damaged or destroyed some of the motherboard components.
Replacing the motherboard on a laptop is time-consuming, labor-intensive, and can be almost as much money as buying a new computer. My recommendation would be to send it back to HP if it's still under warranty -- otherwise, you're probably better off getting a new computer.
There are several things you could try (such as swapping out the CD/DVD drive with another one if you have access to one, or trying external speakers to see if the sound works off of them) but with that many completely separate problems, the issue is most likely the motherboard itself.
Posted on Jul 13, 2010
  • gggg Jul 14, 2010
    Do you have access to a similar computer that you could switch parts with (at least the CD/DVD drive)? Can you try external speakers? If the computer is under warranty, send it to HP to fix, otherwise you'll probably spend more time, energy, and money trying to repair this one than it would cost you to get a new one.
  • gggg Jul 24, 2010
    If you're at the point where you're ready to look at new computers, HP has a lot of good laptops out now. Newegg has the HP G60-630 laptop with a 15.6" screen, Windows 7, and 3GB of memory for $524.99 after rebate and online savings. Or if you're looking for a netbook, CompUSA has a Compaq Mini 102 WH243UT netbook (HP owns Compaq) which comes with Windows XP, a 1.6GHz processor, and 1GB of memory for only $269.99.
    These are only two of the many options you have for a new computer. Generally, new computers run excellently, but if you have been jaded by your current computer, you may want to consider purchasing an extended warranty or service plan.
  • 6,487 Answers
Base from the description of your problem this can be a motherboard related problem, like the USB port and the built in sound wont really work fine even when you first had the laptop.
But if you haven't tried reloading a fresh copy of operating system on the computer that will be a good thing to do , to have a clean installation of operating system on this laptop but if you will still have same problem after that it will really be better if you go get a new laptop rather than having this one repair and have the motherboard replace because that will also cost you just like a new laptop.
  • Mark Gil
    Mark Gil Jul 14, 2010
    If you still want to continue using this laptop , the best thing to do with this problem is to replace the motherboard of that laptop that is causing the problem.
Hp dvd rw drive ds8a1h driver
Check device manger and see if it is listed, if not reboot and see if you can enter bios setup, see if it is listed. If it is not, replace the drive
May 24, 2013 | HEWLETT-PACKARD Hewlett Packard Techno...
How can I tell if my HP Pavillion dv6000 can burn DVDs? I tried to with DVD Flick but the dvd came out blank after 3 hours of supposed burning.
Try creating a normal CD-R for example just a picture using windows transfer which is simply double clicking your CD drive icon in my computer dragging a picture on to it then burn the files should be on the left, if so then your burner should be fine. I Would suggest using NERO to burn DVD's
G
Feb 19, 2010 | Computers & Internet
The cd burner in my computer just stopped working
if nothing working try to uninstall the driver and reintall it and see if that work if not need to change it...go to device manager and delete the device and restart the computer and see if it will load new one.
Nov 08, 2009 | Dell HP Pavilion ZE5000 ZE4000 NX9000...
DVD drive does not show up in Computer drive list
Sounds like a cable or CD hardware issue. If you are comfortable taking apart the laptop yourself, disconnect /reconnect the cable or replace the CD cable. It's hard to update the driver if the system doesn't see the drive. Or, you could replace the drive. It's really hard to know which is the problem without testing.
Jun 13, 2009 | HP 419320-001 - HP Pavilion dv4000 Series...
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
CD/DVD burner
Please don't be borthered your drive selects. So it is left to you to know the kind of dvd or cd that your drive will reject/damage.
Mar 18, 2009 | HP Pavilion dv6000z Notebook
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Computer does not recognize CD/DVD drive
If updating the drive firmware does not work, then replacement of the drive will be necessary.
Jan 30, 2009 | HP Pavillion ZV6000 Notebook
Hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
