How do you wire the Honeywell RTH8500D thermostat so as to operate it battery-free from the main power, yet have battery back up? Info online and in manual does not appear to address this, yet on package it says battery-free operation is optional.
  • 674 Answers
You would need to have a the hot wire from the transformer which would be the red one and connected to R/Rh/Rc. You would also need a common wire from the transformer connected to the C terminal on the contactor. It is usually a blue or brown wire. You would need to look at the transformer in the airhandler to see what color the common is. The secondary wires on the transformer are usually yellow and blue so you will need to look where these connect to the thermostat wires to see which is the common. Also your existing thermostat wire may not have enough wires in it to do this. Let me know if you have any questions.
Posted on Jul 13, 2010
Replacing Thermostat I'm replacing our current battery-operated Honeywell thermostat with a wifi Honeywell thermostat. Our current one does not have a c wire hooked up to it but it does have two unused...
The c in the furnace that is white is going to your condenser, it must stay. ADD the blue that goes to the tstat OR brown, which ever and then use that color on your new tstat and you will be fine. Always turn power off when changing stat
Sep 26, 2017 | Honeywell Heating & Cooling
My heating unit does not have C connector to put my G wire on. What do I do
What is the make / model of your heating unit. With out that information i cant help you with your ac repair problem. If you have any other AC Repair Questions don't be afraid to let us know.
Jul 06, 2016 | Honeywell Rth8500d 7-day Touchscreen...
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
I want to replace a trailer thermostat that has 3 wires to a honeywell 4 wire thermostat . The problem is that the old wire has 3 wire (1w, 2r & 3 orange) the new one calls for 4 wires but wh
If there are both an Rc and Rh terminal, there should be a jumper across the two if there is only ONE transformer supplying power to both the furnace and the a/c. Without the jumper, there is no power on the cooling side of the thermostat.
Also, the Honeywell thermostat may require a fourth wire for the C terminal. Some thermostats 'rob' control power for their operation off of the R terminal wire and others must have the physical connection to the C terminal, and yet others have batteries for the programming portion and when they go dead, there is no heat or cool operation.
Sep 09, 2014 | Honeywell Electronic Programmable...
Touchscreen is not functioning
First try replacing the batteries. I have a slightly diff honeywell model and it takes 2 "AAA" batteries. The battery holder comes out the side of the unit, just press where it says press and pull out.
Sep 11, 2012 | Honeywell Rth8500d 7-day Touchscreen...
I HAVE A HONEYWELL MANUAL THERMOSTAT NO BATTERIES ALL IT HAS ON THE BACK IS T8400C 1099 (2) 0710 1B HELP, IT DOES NOT SHOW ANY THING THE SCREEN IS BLANK
This model of Honeywell thermostat uses the 24v from the unit to power it. One of three things must have happened.
1. You have lost power to the furnace, therefore no power to thermostat.
2. You only have 4 wires hooked up on the thermostat and not 5. A lot of older homes had just 4 wire running to the thermostat, which will not work for this thermostat. You should have a wire connected to the (C) or (B) terminal on the thermostat, which ever one they have, I can't remember off hand. These are the Common terminals. They have to have the common from the furnace 24v power to operate.
3. Faulty thermostat, which will obviously have to be replaced.
Hope this helps and gets you to cooler days!
Jun 28, 2012 | Honeywell Heating & Cooling
My Honywell Thermostat screen is locked. How can I unlock the screen. (RTH8500D)
disconnect the power wait a few minutes and reconnect, this should reset the electronics
Feb 24, 2011 | Honeywell Heating & Cooling
Honeywell vision pro manual rth8500d
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 05, 2010 | Heating & Cooling
How to turn on my honeywell thermostat
Your thermostat should power on without a problem if it is battery operated, and even then, when you put batteries in it, it should still power up. Without knowing the exact model, the only other problem I can think of, the power to the thermostat is supplied by the furnace which is a common wire (usually blue) that is also hooked up to the C terminal on the thermostat. If there is a common wire hooked up, then you have to check if you have power to the furnace. If not, the problems could get more complicated. Hope this helps.
Jun 15, 2010 | Honeywell Programmable Thermostat Heater
Honeywell T8411R 1028No power to the thermostat; breakers are not
site shows this thermostat is a non programmable unit and has been discontinued. none of the info sheets including a pdf shows a replacement battery. this thermostat operates off line voltage only. check for a control fuse or breaker on your heating unit.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
357 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
