Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
My external Hard Drive Doesn't work.
Whenever I try to access my Simple Tech hard drive the computer freezes. Currently when the device is plugged in the computer gets incredibly slower.
  • 1,472 Answers
Trevor_b_smi
If you computer is locking up and or running slow this is a sign that there is a problem with the drive. The computer is trying to access the drive but having trouble doing this. I used to have one of these and had trouble with it from time to time. I would recommend that you try running check disk on the drive to see if this makes a difference.
If you still have trouble try the drive on another computer. Note you may have to assign a drive letter to it. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If you are out of warrranty I would pull the drive out of the encloser to seee if you still have trouble because in most cases when external drives fail the problem is with the USB controller and not the drive its self.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Jul 13, 2010
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
I have a mini simple tech 160gb hard drive that when I plug it in an error message about power surge on the USB port. What can I do to get the data off of the drive
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | SimpleTech Signature Mini 160GB External...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
I have 500GB SimpleDrive USB 2.0 External Hard Drive, but currently i am facing some problems with it. When i plug it in to my computer, the computer says that unknown device. and it also does not come to...
I would unplug the external drive then shut down your computer. Plug the drive in(be sure the USB port is in good working order.)Turn the computer on. If it does not recognize the drive search online for tech support for that particular drive. Install any drivers or software. Be sure to find out if the drive is compatible with your operating software. Make sure all connectors are seating firmly and correctly. Make sure that everything is plugged in where it should be plugged in.
Feb 15, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
My Hp Slimline won't recognize my new Simple Tech Mini-Drive
I`m David ncc student , question is about the characteristics of various network computers (NCs) currently on market? please help me
Mar 08, 2009 | HP S3120N Pavilion Slimline Desktop...
My WD MyBook 500GB drive is causing Windows XP to be self-retardant. (Slows)
Heres what you do.
Don't plug your external HD in while the computer is booting up. It's looking for Windows on your external hard drive. Hence the black screen.
Plug your USB or Firewire cable back in once Windows is finished booting up.
Mine does that sometime too.
Jun 13, 2008 | Western Digital My Book Essential Edition...
Problems
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 15, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
EXTERNAL HARD DRIVE BY SIMPLE TECH 500 GG
First, check the warranty status. They should give you a replacement. The following will probably void your warranty... This external drive probably houses a standard hard drive used in a desktop computer. If you don't mind voiding your warranty, you could disassemble the protective "shell" and check to see that the cabling to the drive is properly attached. I've seen a external drive which the interface cable was partially unattached. If all looks OK here, you could remove the actual hard drive and try hooking it up to a standard desktop computer. If you or a friend is reasonably tech savvy, such is a plus. It could be set as a secondary drive, and then you could see if files could be accessed. If nothing above works, then your outlook is bleak. There are businesses specializing in file recovery from a dead drive, but it is expensive.
Aug 08, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
129 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
