Question about Thermador DWU244 Dishwasher
My thermador dw44zs dishwasher: drain pump runs continuously when turned on even when the door is open. I can't seem to reset the cycle to allow for water to come into the dishwash
  • 414 Answers
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 0426 and 0424. You can also remove 0418 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. If the d/w is connected via a sealed spigot to the sink, remove the grey hose and unscrew the spigot adaptor from the sink and ensure there are no blockages. There may be water in the base of the d/w (base as below the tank, not under the filter) this will activate the flood safety, so check valve, hoses etc for leaks. You will have to manually clear the water from the base pan to deactivate the safety device. Sit the front of the d/w on a large towel and tip the whole unit forward, the base water will then come out. Whilst you have the side panel off, check that the red rod connected to the pressure chamber is not activating the microswitch.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=DW44ZS%2f21&ESHOPTYPE=S
I hope this helps, Good Luck.
Posted on Jul 13, 2010
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Continual draining
has the unit pumped out all the water? It may have a blocked waste hose.
May 05, 2008 | Dishwashers
Bosch SHU runs even when the door is open, what do i need?
Hi Jeffrey,
This depends what you mean by "runs". If the dishwasher continues with a wash cycle - i.e. circulating water - with the door open, the simple answer is that you have a defective door microswitch.
However, I suspect what you perceive to be the dishwasher running, is actually the drain pump running continuously. This happens when the anti-flood protection system has been activated and continues even when the door is opened. The simplest way to check is to open the door (while it's "running") and pour some water into the tub. If the water drains away immediately, this shows the drain pump is running and the anti-flood protection has been activated.
This may be due to water having leaked into the base of the dishwasher, but it could be as simple as a stuck or defective float-switch.
Please try the simple test above then post back for further assistance. If you're planning to investigate or repair this yourself, you're going to need a Torx T20 screwdriver and a multi-meter would be useful as well.
Regards, BElectric
May 25, 2011 | Bosch SHU9915UC Dishwasher
I have a Bosh Logic dishwasher SGS65L12GB/04 The other day it got to 1 min left and would not stop pumping out water and continued even with the door open. After 5 mins playing around it started working...
Hi Jonathan,
Welcome to FixYa.
Your float may have got stuck or it's possible that you have water leaking into the bottom of the washer. In the bottom of the wash compartment, next to the drain you will find a plastic dome/mushroom (the float). You might need to rotate the bottom spray arm to see it.
Turn the washer on so that the pump starts to run, open the door and push down on the float. This should stop the pump running. When you let go of the float, if it rises back up on its own, then it's almost certain that you have water in the bottom of the washer. If this is the case please post back for further assistance. If the float stays down, then it may have simply got stuck.
Please try this simple test and post back with the results.
Regards,
BElectric
Nov 11, 2010 | Bosch Dishwashers
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
I just replaced the drain pump in my bosch shu3307uc dishwasher.When I turned it on it filled with water and then I put it in the drain mode' It drained but it would not allow me to advance to start the...
You have to allow the drain cycle to finish completely, or find cancel drain dot points and press both at the same time, to reset program, open the door and close it to make sure the micro-switch activate properly
Jan 06, 2010 | Dishwashers
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Dishwasher drains continuously
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Mar 27, 2008 | Dishwashers
Bosch SGV43A03 DISHWASHER: pump drains all the time, even if reset!
Typically you could possibly have a leak in the base or sump which activates a little float switch. This in turn switches the drain pump on continuously and deactivates the programing cycle.Sort out the leak.
Feb 24, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Thermador DWU244 Dishwasher Logo
488 people viewed this question
Top Thermador Dishwashers Experts
ray gallant
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
