HP LaserJet 2840 All-In-One Printer Logo
Posted on Jul 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop running XP desires to connect to desktop running windows 7-driver needed for HP 2840 color laserjet before connection to windows 7 desktop-is driver put on laptop or desktop
Anonymous
Level 1:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Contributor 26 Answers
  • Posted on Mar 14, 2013
Anonymous
Contributor
Level 1:
Filmmaker:
New Friend:
Answers
26
Questions
Helped
13823
Points
72
had the same problem. It was due to incorrect properties in the printer settings.
  1. Go to Start >> Printers and Faxes
  2. Right-click on the HP 2420 printer and select Properties.
  3. Go to the Device Settings tab.
  4. Under Installable Options, set Duplex Unit to Installed.
Also, make sure that the Printing Preferences are set to Two Sided Printing:
  2. Right-click on the HP 2420 printer and select Printing Preferences.
  3. Go to the Printing Shortcuts tab.
  4. Select the Two Sided (Duplex) Printing option.
That should do the trick.
Al Toledo
Level 2:
  • Expert 223 Answers
  • Posted on Jul 14, 2010
Al Toledo
Expert
Level 2:
Answers
223
Questions
0
Helped
148944
Points
476
There is no driver for win 7, although if you are running on windows 7 32bit there is a work around. Download the software for windows vista 32 bit for the 2840.
2answers
Need default printer driver for color laserjet 3800n for windows 7 32 bit operating system
The Windows 7 has a compatible driver for many teams, try your printer is a greatadvantage when connecting it almost immediately begins to install. And do not waste your time searching for drivers on the network, there is little to W7
Color laser jet 2840 is not scanning. It says: pc not set up. I have the connections in properly from my lap top to my laser jet. What is the problem
I had a similiar problem and was using Windows Vista which was not compatible with the XP Installation package. The onboard drivers would not work either. Check to see if your printer is compatible with your version of windows.
My HP 2840 Printer not fully functional via USB with my HP KQ752AA Docking stations (running Windows 7 32 bit), but if connected directly to the laptop it works...what is the problem w/the docking station?
Are you using the same cable to connect? The 2800 series printers do not tolerate USB cables over 10 feet and I have had some that would not connect properly unless a 6 foot cable was used. If you are using the same cable then it is possible that the drivers for the docking station are not installed properly on your laptop and you might need to update them from the manufacturers website.
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
We have downloaded the HP 2840 software and drivers and installed it. But the scanner is not working. The Icon in the desktop is not displaying only HP image and Software updates. Help us
Are you using Windows Vista, try using a computer with windows XP. for some reason the HP vista driver is not always compatiable with windows vista.
Hp color jet 2840 cannot scan on windows vista but can print
The problem is Vista. I had a similar problem and the only solution at the time was to remove vista and install good old reliable XP. Now just put windows 7 on and you should be ok.
1helpful
2answers
Hp Laserjet 2840 was scanning, suddenly it stopped and gave the message "An error occurred communicating with the scanning device. Please ensure that the scanning device is connected properly and try...
I pulled this from the HP boards from Charlie Bravo
I tried it and it worked for me. (this is a network setup.)
MY FIX (Windows XP):
After trying numerous things, here is what I resolved:
1) Problem: when trying to scan using my 2820 Color Laserjet using "Solution Center", I got the dreaded, yet common error: "An error communicating with the scanning device. Please ensure that the scanning device is connected properly and try again"
My device: HP LJ2820 Color Laserjet
2) The printer worked fine when printing to it and also, scanned fine when using the Windows Wizard (Start/All Programs/Accessories/Scanner and Camera Wizard
3) Hewlett-Packard Support was less than worthless since they used my time and provided no useful information. Their ineptitude is legendary as we all know... To add insult to the injury, the rep wanted to charge me $25 for the "incident" which happens to be to not only identify teir bugs but also to report and fix them as an unwitting test site. Arrogant of them to say the least !
4) SOLUTION: Added an entry in the HOSTS and lmhosts file (this file is located in WINNT/SYSTEM2/DRIVERS/ETC ):
192.168.1.1 HP Color Laserjet
The 192... etc is the default gateway for my printer (look in toolbox and get the network report for yours, my printer is connected using the network, wired to a Linksys router)
Dont's bother with "reinstalling", "de-installing", etc. the problem is related to addressing and not corrupted drivers. It's simply a HP bug, nothing else.
5) Ran the "patch" col10862.exe from the hp site, listed under an unrelated problem to an unrelated printer. http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=sj-32245-2&jumpid=reg_R1002_USEN
6) Now I can can use the the scanner I paid for...
7) Time to resolve the issue: 2 minutes. time to find the resolution to the issue: 4 hours.
k24674
Grand Canyon Tech
Grand Canyon Tech
