Question about Intel Computers & Internet
MY COMPUTER IS START BUT SHUT DOWN AND START NOT
MY COMPUTER IS START BUT SHUT DOWN AND START NOT POWER SPLAYERS IN VOICE TIE TIE WHY? WHAT PROBLEM?
    Sergeant:
  • 191 Answers
Install your operating system again. you have a virus i believe.
Posted on Jul 19, 2010
Tip
Quick Tip: How to correctly shut your computer down
This may seem like a simple tip, it is, however it can cause many unneeded problems to your computer if you do not shut it down properly. Do Not shut down your computer by pressing the power button. Whether you have a PC or a laptop, don't use the button. When you go to shut your computer down go to start and shut down and it will shut off. If you do not do this correctly it doesn;t give your computer the proper amount of time to shut down, you can corrupt your Windows files and eventually have problems even booting your computer up. Simple solution that will avoid future problems! Hope this helps!
Lori
on Oct 18, 2010 | Computers & Internet
Laptopp plugged in not charging
What's your OS? Someone claimed to have resolved this problem following the steps below:Shut down Computer. unplug AC. Take out battery. Plug in AC. Start up computer. Disable Microsoft ACPI CC Method Battery Shut down computer. Unplug AC. Insert battery. Plug in AC. Turn on. Enable Microsoft ACPI.
Then it was working.
Original post:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Of course, there were some different voice on this post. Have a read, and may this help.
Nov 20, 2011 | Computers & Internet
I think it is the power supply. It is a Besttec ATX-200-12Z Rev D mounted in a Compaq 6450NX desktop PC running Windows XP Professional Computer will (intermittenly) start up, and shut down on it's...
While it could be the motherboard it does seem more likely that it is the power supply.
Here are two options to test your theory:
1. If you have another known good power supply or can borrow one, hook it up to the motherboard and see what happens.
2: Or, if you have a known good motherboard or can borrow one (does not have to be the same as yours of course) hook your power supply to it and see what happens.
Jun 20, 2011 | Bestec (ATX-250-12E) 250-Watt Power Supply
Voice light computer has been shutting down and will only work after rebooting with power switch. At first it shut down rarely, maybe once every two months. Then it became once a month, once a week and...
This is likely one of two things:
A power supply issue in which case you have the power supply replaced.
The server is overheating. There could be many reasons for this: Dust, loose parts, bad ventilation, etc.
Mar 06, 2011 | Comdial SmallOffice Lite Voice Mail Server
How do i get e machines out of safe mode so i can reboot the computer?
If you are in safe mode, you should be able to shut down or restart the computer the same way you would in standard mode. Click the start button and select shut down or restart, and let it boot up normally. If you do not have the start button, you can try holding down control-alt-delete and selecting shut down from the menu. If all else fails you can hold down the power button on the computer for about ten seconds and the computer should power off, then you can turn it back on.
Jul 21, 2010 | E-Machines eMachines Desktop PC
Subwoofer shutting down..
if its shuting down the voice coil is probley bad! u need to replace it ! i got 2 1200watt square subwoofers and they did the same thing . it was the voice coil!
Nov 20, 2009 | Creative Labs GigaWorks ProGamer 5.1 G500...
Monitor just went blank, no power light.
Was the PC running, and then shut down? Or, did it never start in the first place?
It sounds like it could be one of many things. Sometimes if the processor fan has failed, the computer will start up, and then shut down. Also, bad memory can cause the PC to shut down.
Jul 05, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
