Question about Dell F3534 Touchpad
Where do I find touchpad setup? - Dell F3534 Touchpad
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
If you have already downloaded the software and drivers, it should be in
C:\Program Files\DellTPad
That's where it is on my dell laptop. If your's is different, let me know i'd be glad to help further.
Posted on Jul 13, 2010
Want to turn off touchpad,because it disturbs my writing
You can disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. You can even disable the touchpad from the BIOS setup [press F2 or del when the computer starts to enter BIOS settings].
Sep 06, 2011 | Computers & Internet
Tip
Dell Latitude Portable (2008 or newer) has jumpy cursor when typing
The Touchpad driver setup has options to keep the cursor from jumping while typing.
  1. Open the Touchpad Properties
  2. Touchpad Settings
  3. Enable the TouchCheck option, set the slider to minimum. (TouchCheck disabled the touchpad while typing. The Slider adjusts the delay. Minimum is .5 second delay, and each notch and additional .5 second delay)
Other options that may cause user problems are Draglock and Tap to Click under Touchpad Settings, and Scrolling and Zoom Settings of Touchpad Properties.
on Jul 12, 2010 | Computers & Internet
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
My my touchpad doesnt worrks
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, option here to Disable,
Feb 23, 2010 | Dell F3534 Touchpad
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Have a Dell Latitude laptop and the touchpad just stopped working
For some reason most latitudes have this problem, I don't know why but its some problem with both the software and hardware setup.
Sep 27, 2009 | Dell F3534 Touchpad
Synaptics Touchpad not working properly
http://www.synaptics.com/support/drivers  download and setup your touchpad driver again. if still countine your problem then you may have a hardware problem with notebook. have a nice day and sorry for my english.
May 27, 2009 | Lenovo IdeaPad Y510 Notebook
Frozen touchpad
Did you try the Fn+F7 combo, the F7 is usually assigned to the touchpad and is indicated by an icon that's relevant.
This works on most notebooks to turn on or off the touchpad.
Let me know, as this can also be turned on or off in the bios setup pages. Press F2 or F10 (it varies) to enter your bios setup screens. In these pages is a setting for touch pad only, mouse only or touch pad and mouse or serial. You might check that.
Regards,
Worldvet
Jul 30, 2008 | Computers & Internet
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
225 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
