Question about Kenmore 44072 Front Load Washer
Push start and nothing happens
Close door and the doorlock locks door and there are someother click noises but no water enters and then after some time the machine beeps and all the lights in the right hand row blink.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you are sure that the door will lock firmly then check the water inlet valve, try to clean clogs and if it’s bad replace it. If everything else seems to be working fine then it is the control panel that should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 13, 2010
Front Doors LOCKED OPEN.. How to close?
Lift the door handle as if you were opening it
Hold the handle & use a round phillips to hook
& rotate the white door latch to the open position
May 18, 2014 | 2009 Honda Odyssey
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
My avital 4103 will not lock or unlock my doors on my 01 crown vic
It sounds like you wired up the door locks incorrectly. You need relays to control your doorlocks. Follow the diagram in this link to wire up the relays.
http://www.the12volt.com/doorlocks/page3.asp#5w
Jan 06, 2013 | Remote Start System
When I close the door and push start it makes a buzzer sound and then nothing happens, sort of like it is not locking properly.
Hi - From what you have described it sounds like the door strike is not aligning with the door lock or the washer possibly has a defective door switch. I would suggest contacting a professional to move forward accurately and properly diagnose the unit.
Oct 14, 2012 | Frigidaire FTF2140E King-Size ENERGY STAR
Have peugoet 207 3Dr problem with doorlock..I tride kids safetly lock,pushing lock down on side of door..And know lock doesnt open, cannt close door??????????
you will need to remove the trim with the door shut ,the pop the lock with a screw driver to get it opened,it would be better if you took it to a mechanic
Apr 30, 2012 | Cars & Trucks
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool AWO3761
hi we have a whirlpool awo3761/5 when wash is selected it goes to start but then doorlock flashes a nowt happens, i have just replaced with new doorlock this morning and with fingers crossed tryed again it looked promising but doorlock started to flash again and nothing happens pls pls help
Sep 07, 2009 | Whirlpool Washing Machines
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 44072 Front Load Washer Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
