Question about EdgeStar Titanium Portable Ice Maker
Add Water issue on Edgestar icemaker
My edgestar ice maker has the "add Water" light on even though there is plenty of water...any tips?
  • Suzi Alonzo Jun 30, 2013
    Would this also cause the water to run and run and run? The water flow doesn't stop to let the machine make ice. Been working like a charm till this morning,
This also applies to the Igloo ICE102.
There is a sensor at the water outlet which fills the ice-making trough, which appears to be poorly assembled. The fix is quite easy.
Remove the rear cover by removing six screws located underneath the unit at the back and sides. Keep the ice-maker upright at all times, per user instructions.
Once you have gently pried the back cover off, remove the top cover and hinged lid by removing two screws on each side, located underneath the top rim.
With the top off, you can see the water outlet at the back left side. Above the inlet is the offending sensor, which has a metal prong angled down. This prong must touch the water stream to detect the flow, but is probably too high. You can check this by filling the unit with water and turning it on. Watch the water as it fills the trough. With the tip of a screwdriver, bend the metal tip down so that it touches the water stream. Run the unit for a while to test.
If everything is ok, then reassemble and enjoy!
Thanks to jimbo from Tampa who provided the hint for this fix.
Posted on Dec 31, 2010
Actually ,the problem "no-water" is not the sensor , its the water pump. when the I/M sits for an extended time of no use, the water inside the pump gets "thick" (dirty , algae, slime, pudding etc.) the pump will not come up to speed & produce enough water flow to contact the water sensor. so clean out the pump & enjoy your amazing little I/M again !
Posted on Nov 10, 2011
My ice machine is so loud and the water is filled to the line and
it says add water then it shuts done
Posted on Nov 25, 2015
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
Edgestar ip211ss water valve level problems
This unit will pump water into the upper reservoir and at that point it should start the compressor and make ice , if it countinues to fill the upper and flow into the lower than your water level device is not registering .
May 24, 2014 | EdgeStar Portable Stainless Steel Clear...
My model number is IP210PK.tried everything in mannel but won't work. filled with water but red light for "add water" comes on. Fan wont come on at all bouhght on october 17,2012. need circuit board. will...
Parts are almost impossible to get for this machine. Cheaper to get a well known brand like Scotsman, Manitowoc, ice- o -matic. you can get parts for these machines anywhere in the U.S
Sep 18, 2013 | EdgeStar Stainless Steel Compact Portable...
My EdgeStar Full Size Ice Maker IB650SS won't stop making ice
The eye needs to be re aimed at the target directly across the bin. It has to be clean too.
Mar 29, 2013 | EdgeStar 65 lb. Capacity Full Size Ice...
My EdgeStar Portable Ice Maker stopped making ice
The ice bucket is probably cracked we have had three that have all done the exact same thing all different name brands. Just order a new ice bucket. Good Luck and my advice is to purchase a extended warranty on these because its not a matter of if it will break its when. Edgestar lasted the longest it lasted 1yr and 7months.
Aug 04, 2009 | EdgeStar Titanium Portable Ice Maker
Ice bucket broke on my edgestar, IP210TI, ice maker
call Edgestar support at 1-866-319-5473. i had the same probvlem with my ice maker and had no problem ordering a replacement with installation instructions
Feb 13, 2009 | EdgeStar Titanium Portable Ice Maker
EdgeStar Titanium Portable Ice Maker Logo
1,120 people viewed this question
Top EdgeStar Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you an EdgeStar Kitchen Appliances - Other Expert? Answer questions, earn points and help others
