Question about Kenmore Elite HE5t Washer
Stops and has a code sais F21 press stop and it sounds that it is draining and takes a while
  • 5,081 Answers
The F21 error code indicates a long drain. Here are some tips that should help you resolve this problem:
  • Check your washer drain to make sure that it is draining properly.
  • Check the drain hose for kinks and clogs. Make sure that it is installed properly per the instructions in your owner's manual. An improperly installed drain hose can prevent the washer from draining properly.
  • Check for excessive suds in the washer tub. Excessive suds can prevent the washer from draining properly and will result in the F21 code. Make sure that you are using the proper amount of HE (High Efficiency) detergent to prevent excessive suds.
Remove any clothes and then use a wet/dry shop vac to drain any water out of the washer.
Arrange shallow pans and/or towel in front of the large item filter shown in the second image below to catch residual water when you remove this filter.Remove the large item filter as shown below. It is likely that you will find a clog in this area that is preventing your washer from draining.
If you do not find any clog or restriction in the large item filter and none of the other issues discussed above apply to your situation, then you could have a failed drain pump. If the pump is damaged and will not pump out water then it will need to be replaced.
Posted on Jul 13, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
I am getting a code F21 it stops about 15 min through a cycle
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Sep 15, 2011 | Kenmore Elite HE5t Washer
The machine washes for a few minutes and stops with F21 flashing below the time remaining ,the door is locked and it doesn't restart
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Apr 07, 2011 | Maytag MHWZ400T Front Load Washer
I have a whirlpool frontload washer with model number WFW83005W00 and I have an error code F21 that flashes and then the washer stops working. What does this mean and what should I do?
Means the drain is taking too long . Most likely that the drain sump filter is blocked. Remove the lower front panel and unscrew the large white thumb screw attached to the pump. Water will come out so collect it then clean and replace.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code f 21, what does this mean?
The error code F-21 refers to Long Drain. The washer has sensed that it has not drained out completely and cannot go into further cycle.
If yours is a HE 2 washer, afer few minutes, Sd error will be displayed and then after couple of minutes F21 error code will appear. Water valves will be turned off and stops running.
If yours is a HE front load, when drain time exceeds 8 min, F21 error will be displayed. The water valves will be shut off and pump will stop running.
Generally, by re-storing the power to washer, it may fix the problem.
You may press the pause or the cancel button twice to clear the display.
You may have to double check the drain hose to see if there are any kink, clogs.
Also, you may unplug your washer, turn the circuit breaker off for 1-2 minutes and then plug it back in to check if it works. After this, check to see if the washer drains.
May 18, 2010 | Washing Machines
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 11, 2009 | Kenmore Elite HE5t Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 code wfw8300 sw
 “Rinse,” “Cycle Complete” and “Add a Garment”
illuminated or “F21” on display (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
 Any other Status light combination (Electrical Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Feb 20, 2009 | Whirlpool WFW8300SW
My washer stops in the middle and flashes F21?
Hi and welcome to FixYa,
An F21 error code indicate drain problem. Might you want to inspect/clean the drain system from the filter to catch basin to impeller, pump/valve and drain hose. To do this, the bottom/kick panel ahs to be removed. A bit of a messy job so pls be prepared with paper towels and other absorbent materials.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
546 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
