Question about Drills
Ramset dyna drill 342, what type and how much oil goes in the gearbox and also the hydraulic piston?
  • 10,865 Answers
Hi. Your ranset product is not currently listed with the company so this is what I recommend. Contact Ranset directly and tell them which tool you have. They should be willing to make you a happy customer. http://www.ramset.com.au/public/contactUs.asp?menuNo=1
J.
Posted on Jul 15, 2010
What type of modern SDS drill bit fits a Hilti TE 72?
sds is a standard adopted by all rotary hammer drill manufacturers
It is the design of the slots and grooves in the end of the drill where it goes into the machine
it allows for many drill manufacturers to get their drills to fit any rotary hammer drill
early ramset drills used a special drill but they found that it was better to use the standard as well
Sep 04, 2017 | Hilti Drills
Where in Tauranga can I get a new battery for this 18volt Procut?
18V Battery and Charger - Ramset New Zealand
www.ramset.co.nz/Product/Detail/265/18V-Battery-and-Charger
18V 40Ah Heavy Duty Lithium Ion battery and 18V charger.
Oct 27, 2015 | Drills
Where can i purchase a trigger switch for a ramset 332 dyna drill
It is a Bosch Drill contact them for parts. If they have them as it a 1970 drill by them. Hard to get some of the parts, but good dril
Jun 07, 2015 | Drills
No reverse ranger automatic transmission
Loss of reverse gear in an automatic gearbox
Broken Reverse selector Band
Brake material on Selector band is Worn out
Selector band needs sever adjustment
Selector bands hydraulic piston seal had failed
Selector not getting oil to work the piston.
Apr 03, 2014 | 1998 Ford Ranger SuperCab
Hydraulic jack
check the piston seals are not damaged.. Check the non return ball has not got something stuck under it .
Jul 11, 2013 | Air Tools & Compressors
Need Shaft & bearing for a: Dyna,1HP,60cycle, 1 phase, 1750RPM, Frame = RL203, SN=4304154, Cat# 5968? Where can I get?
WOW - I'VE LOOKED UP ALL POSSIBLE DYNA DRILLS AND I DON'T THINK YOUR DRILLING FOR OIL, BUT UNDER DYNA DRILL DRIVERS I FOUND A WEB SITE FOR RAMSET THAT HANDLES THIS PRODUCT BUT COULD NOT FIND YOUR MODEL CHECK SITE AND SEE WHAT YOU CAN FIND
Sep 16, 2009 | Electric Drills
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Why does the 905 breakermachine fail to start to
It sounds as if it is low on oil. the oil filler cap on the bottom of the breaker is just for the gearbox. The drive piston and crankcase oil is seperate but you have to strip the machine to top it up , I would recomend servicing the machine at the same time. the crankcase takes 80cc of hydraulic oil DO NOT OVER FILL IT. if you need a parts diagram or some more advise...paul@wysehire.gi
Jun 25, 2009 | Hilti Drills
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Drills Logo
363 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
