Question about Maytag Kitchen Ranges
Maytag M920 gas range, 5 years old today and the controls all stopped working!! (clock, cancel, bake, etc.) oven light comes on, top burners light but can't use oven-we unplugged and replugged.....can you help?? never had ANY problems before with this...
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
aborcass
  • 2651 Answers
SOURCE: MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Posted on Mar 06, 2008
  • 184 Answers
SOURCE: Freestanding Electric Maytag Stove /Oven (with 4 burners self clean w/clock)
I WOULD LOOK AT THE DOOR LOCK ASSEMBLY AS THE DEFECT. THERE IS USUALLY A SWITCH THAT TELLS THE CONTROL IF THE DOOR IS LOCKED OR NOT. IF THE SWITCH HAS SHORTED CLOSED, THE CONTROL THINKS THE DOOR IS LOCKED AND WON'T DO ANYTHING BUT CLEAN.
MOST OF THE ASSEMBLIES ARE UNDER THE RANGE TOP.
YOU MAY HAVE TO REMOVE TWO SCREWS FROM THE UNDERSIDE OF THE TOP AT EACH OF THE FRONT CORNERS. OPEN THE OVEN DOOR TO GAIN ACCESS.
IT WILL BE LOCATED IN THE CENTER. THE DOOR HOOK THAT STICKS OUT TO ENGAGE THE DOOR IS PART OF THE DOOR LOCK ASSEMBLY.
Posted on Apr 04, 2008
yalmer
  • 549 Answers
SOURCE: Tappan TEF242BW oven stopped working
Have you tried the broil setting yet?
This will tell you if the upper element comes on.
If so, you may have a burned bottom element.
Posted on Apr 05, 2008
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
OVEN BEEPS FLASHING -F7- IN CLOCK WINDOW
F7 indicate that the EOC (electronic oven controller) will need replacing. Parts are available at http://www.repairclinic.com/
Thank you for using Fix Ya
Please take the time to rate this solution.
Feb 03, 2009 | Maytag MER5755QAS CleanDesign Electric...
Bake and Broiler do not work
it sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag Gas Oven top burner does not turn on when in bake mode
That is the way it works. If you have an convection oven then they both work in bake mode but they alternate between the two.
Dec 17, 2008 | Maytag MGR5751AD Gas Kitchen Range
I was baking in my Maytag range when there was a loud popping noise and the oven stopped working. The broiler, clock and timer do not work either. The control panel will do nothing. The burners work and...
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Jul 11, 2008 | Maytag Kitchen Ranges
Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Mar 23, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Kitchen Ranges Logo
121 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
