Question about Whistler Power Inverter
I will like to know if one can get an inverter that can server for about 20hrs or so
  • 760 Answers
You haven't supplied enough information. An inverter only converts 12V DC to 115V AC. There are some battery packs with inverters, but that's not what you asked about. The time it "serves" is dependent on the load being connected and the battery(s) that the inverter is being supplied from. Go to a web site such as :http://www.donrowe.com/inverters/inverter_faq.html#hookup
You can learn a lot about inverters here.
Posted on Jul 13, 2010
1 long 4 short alarm for DF225Z
I'm not sure try this
There is an alarm and the oil ,symbol flashes when its due for an oil change, 20hrs then every 100hrs, or overheating, low oil or clogged oil filter
Mar 30, 2014 | Boating
MY MC1000 SCANNER COMES UP WITH BACKUP BATTERY LOW HOW DO I FIX
when the unit is totally drain (main battery and back-up batter is totally drain), you need to charge the device at least 20hrs to fully charge the main and back-up battery check manual of mc1000 re battery charging @ page 21-22
Sep 16, 2010 | Symbol MC1000 Barcode Scanner
What the different between srinc & source
Sinc is a domain controlled by two servers. They are on different IP networks
Source
project oriented program code editor and code browser, with built-in analysis for C/C++, C#, and Java programs,
Nov 03, 2009 | Inverter Yaskawa F7 Drive
Is there any problem connecting Inverter and UPS in series for backup to computer?
Why would you want to do this?
The UPS has it own battery and inverter and can supply power to the computer/server and if the power interruption is too long and the battery power is unable to maintain power to the computer/server, it can initiate a shutdown procedure so the computer/server can shut down in an orderly fashion without losing data.
The size of the UPS with its batteries and the power requirements of the computer/server can be calculated to give a a capacity from as little as 30 mins to hours.
There is no need to run a separate charger, batteries and inverter to supply power to an UPS (it has all these buint-in) and it is an unnecessary additional complication.
Oct 23, 2009 | Microtek scanmaker 3840
I am looking at the same problem/solution
Ok, Heres the deal. A gel cell battery is 7.2 Ampere hrs, so to get 14,4 Ampere hours you would need two batteries connected in parallel. A F&P machine such as mine consumes around 60 Watts of power. Using Ohms law we get W= IxE or Watts = volts X amps[or amperes = watts / volts] so that a 60 Watt machine has a current draw of 60/110< =0.55A so that a 14.4 A/hr battery will run this machine for around 20hrs (allowing a residual charge of 25%)
Jun 23, 2009 | Duracell Standby Power Plug 400 Watt...
Flashing light - unable to locate in manual book to what it is.
Local service agent beleives it is the heater element causing the problem. We are not using the freezer and when the alarm sounds we turn it off for an hour. This seems to fix it temporarily (20hrs), now waiting on parts to arrive.
Dec 11, 2008 | Jenn-Air JCD2389G Side by Side...
Whistler Power Inverter Logo
73 people viewed this question
Top Whistler Electronics - Others Experts
Are you a Whistler Electronics - Other Expert? Answer questions, earn points and help others
