Question about Dell Inspiron 530 Desktop Computer
Clean install Need to know how to install Windows & from a clean install
  • Narayan Jul 13, 2010
    first of all tell me which version of windows you want to install. and if you want clean install means you have to format your system atleast C: drive. and install windows. that is the clean installation
  • lhtphoto Jul 13, 2010
    Windows 7 pro. I need some direction as to what the entire process should be so I don't screw things up.
    Problem Solver:
  • 11 Answers
Put windows cd in the drive and press restart and it will ask boot from cd... press any key..so u press any key it wil boot automatically..thn you can follow as per the screen viewed
Posted on Jul 13, 2010
Cannot get quickcad to function in Windows 8
If you just allowed a windows update, you should know the answer to your problem. I had to use a retail windows disc to get a new gateway notebook to install windows 8 because gateways recovery disc's wouldn't work & yes I know which BIOS setting to use. back to your problem, windows 8 updating has caused a ton of problems with new PC's. So my advise to you is use an earlier restore date & see if that fixes your problem. As for update settings. I always use "Allow me to decide what to download & install" & friend Microsoft adds that screwed up popup at the bottom of the desktop like you're making a mistake by choosing that option however, half of those updates just take up hard drive space. I only install hardware installs & net framework. Both of which I can remove if need be [running windows 7 on 5 laptops/notebooks & 1 with 8 on it....] Good luck with yours....
Jan 15, 2014 | Autodesk QuickCAD 8 Full Version for PC
Windows xp cd with sp3 installation
In BIOS change the boot order such that CD/DVD comes first. You will also need to make sure your hard drive runs in IDE mode since Windows XP doesn't support sata drives by default. FYI XP is going end of life early 2014.
May 20, 2013 | Microsoft Windows XP Home Edition
Have windows 7 on new computer, installed Adobe Pagemaker which is fine but want to turn files into PDF format, message say's no printer driver installed. Have tried to install but windows will not let...
the printer will need to be installed in compatibility mode....un-install the printer from control panel.
pain in the **** i know, but least you'll know from now on, how to install older programs & drivers in to windows 7....
if your installing from a disk, then put the disk in, then when the auto run box comes up, close it...
open computer instead from the start menu.
right click on the cd drive with the disk in, & select open.
drag & drop the contents of the disk on to your desktop....make a new folder to put it all in, if you need to.
then once it's copied across, right click on the install/application icon.
from the top of the menu click "check compatibility" if you dont see it,click off it & then try right clicking on it again untill you see it.
windows will scan & set itself to the right settings for that program.
then click try recommended settings.....followed by START PROGRAM.
if it all installs ok click next then click YES KEEP THESE SETTING FOR THIS PROGRAM NEXT TIME.
then go to the printers web site & update it with the latest software,thats if windows doesn't do it for you.....TIP:(white flag @ bottom right of screen)
do this with all older software.....windows 7 is **** hot when it comes to running older programs, im using a windows 98 program call photo express on mine...no problem.
GOOD LOOK MATE.
Sep 10, 2011 | Computers & Internet
I have a lexmark Z53 printer. Our computer crashed and everything was wiped clean. We did get the computer (Dell 2600 Inspiron) (windows XP) running. Now I cannot get my printer connected.I have down...
Hi, you may download your driver through this site:
http://support.lexmark.com/index?page=downloadFile&actp=CONTENT&productCode=&id=DR764&segment=DOWNLOAD&userlocale=EN_US&locale=en&oslocale=en_US&osVendor=MICROSOFT&osCats=Windows+Server+2003+%2832-bit%29%2C+%3Cwbr%3EWindows+XP+%2832-bit%29
Once your in this page, please click on "CJXP53SE.exe"
Lexmark Z53 Certified System Driver for Microsoft Windows XP and Server 2003. Once downloaded, double-click the file to extract the driver. Then, follow the on-screen instructions. This driver must be installed through the Add Printer Wizard. If you have a previous copy of this driver installed, uninstall it prior to installing this driver. i hope this helps.
Aug 07, 2011 | Computers & Internet
How to clean install windows xp home
http://www.buildeasypc.com/sw/windows_xp.htm
May 12, 2011 | NEC Computers & Internet
How do i wipe laptopt and restart fresh?
You need to have the OS CD to do that. More often than not once the CD is inserted the installation process should in case it doesn't start then you need to change the Boot Sequence and the complete step is mentioned below.
Its Simple you are sure to like it.....Try it Out....Good luck
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation >Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
Nov 16, 2010 | Microsoft Windows Vista Ultimate Edition
Plz Help me ....How to Format Computer.......
How to Format a Computer
Want to know how to format a computer hard drive? Need to learn how to format your computer and start with a clean slate? Formatting a disk prepares the surface of the drive to accept and store data. Computers are often formatted before they are sold, donated, or returned to an employer. Likewise, computers with viruses or errors can be formatted and returned to their "out of the box" settings.
How to Format Computer Quick Links:
Oct 25, 2010 | Computers & Internet
I like to install windows7 what i need to do?is
So far Windows 7 is turning out to be not only the fastest booting operating system but the most stable and user freindly...it is also very good at diagnosing its problems and fixing them. Download and run the Windows & advisor tool. This will scan your system and let you know if you have any possible trouble spots such as unsupported hardware or software. Now, drivers for devices are still not 100%, but if your machine originally came with the Vista Operating system then more than likely you are not going to experience any problems with the upgrade, Windows 7 is an upgrade to this and not a clean install.....but if you have XP, then you need to save your files to an external drive because Windows 7 cannot be upgraded from XP, it will do a format and clean install on your computer. There is a chance it will recover all your old XP files and programs and put them in a folder called "old windows", it will appear on your "C" drive. You can access your documents, pictures, music, etc....but programs may not run properly from that folder because there are no registery entries for them. Below is the Windows 7 advisor link......
http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
Nov 04, 2009 | Gateway MX6920 Notebook
I need to know how t wipe the harddrive clean so i can start over
Insert your recovery CD that came with the computer, reboot, and follow the prompts to make a new partition and reinstall Windows.
Oct 31, 2009 | Gateway GT5220 PC Desktop
Can not find my windows disk for a dell Dimension 9100. Loaded normal windows on to the computer, but it keeps giving problems at start up...Were do i find Windows Xp for a dell computer?
The problem is that you don't have all of the Dell-specific drivers for the OS. You can download them here: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_9100&os=WW1&osl=en&catid=&impid= If you enter your Service Tag, it will display the drivers for only the devices you have installed. Also note that there are other applications (such as Sonic for burnind optical discs) that are also available from this page.
Jun 05, 2009 | Dell Dimension 9100 PC Desktop
Dell Inspiron 530 Desktop Computer   Logo
55 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
