Question about Dymo LabelWriter 330 Thermal Printer
My compter was in the shop. He wiped everything out then redone. Now my Dymo LabelWriter 330 will not work. The green light is on and all is plugged in correctly. PLease help.
    President:
  • 567 Answers
Hi there thanks for asking,if you mean someone wipe everything off the computer and reinstall the operating system,you need to install the drivers for your printer. Please visit http://sites.dymo.com/Support/Pages/Drivers.aspx#LabelWriterPrinters(DYMO)TOP select your model of printer and download the drivers.
Posted on Jul 13, 2010
Not printing correctly
When you go into the software to prepare the label you should see buttons to select whether you want the label formatted from the left, right, or centered. Also, when you type the text onto the label you will probably see dotted lines around the label which can be moved slightly to help you get the print arranged on the label. Hope this helps!
Nov 12, 2013 | Dymo LabelWriter 330 Thermal Printer
Dymo LabelWriter no power
It's probably time for a new ne since they aren't very expensive.
Jul 30, 2017 | Dymo LabelWriter 330 Thermal Printer
What is the life expectency for these? Mine doesn't come on even with the AC plugged in
We've had our Dymo 330 Turbo for years and still use it daily to print all our address labels - never had a problem with it. They come with a 3 year warranty, so I guess Dymo thinks they're going to last at least that long.
If the power supply has had it you can get a replacement power adapter but if the machine has had it then time to get a new one I think.
The 300 series was discontinued years ago, and even the 400 series has now been discontinued and replaced by the Labelwriter 450 series.
Oct 24, 2009 | Dymo LabelWriter 330 Thermal Printer
Won't turn on
The 330 series don't have an on button (they are on all the time, unless you unplug them), so presumably you are saying it is plugged in but the light is not on, the button on the front doesn't respond, and it doesn't print.
I'll assume that you have checked that the power supply is plugged in to a known working power socket and the socket is switched on if applicable (depends on country), and that you have checked the power cable is firmly plugged into the labelwriter.
Check to see if the power supply has an LED on it. If it has but it is NOT lit, and is definately plugged in then it is probably a dead power supply (or possibly a blown fuse).
In this case you can try a replacement power supply: Dymo LabelWriters (2nd item from bottom)
If the LED is lit then it would suggest that the labelwriter is broken.
Oct 08, 2009 | Dymo LabelWriter 310 Printer
Dymo 330 printing cartridge
Try cleaning the print head with a Q-Tip dipped in alcohol.
Lou
Sep 16, 2008 | Dymo LabelWriter 330 Thermal Printer
New labelwriter 400 turbo will not print under windows 2000
I had the same problem and accidently discover it was something very simple...at least in my case. I noticed the power cord connection was very good.. I notice the light on the transformer (cord) was sometimes green then it would go out. When I unplugged and then put some force into reconnecting the printer worked. Hope that helps.
Jul 10, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Hi, i am on vista at the moment but it will not reconize the usb port for the dymo labelwriter
THe printer is not compatible with the current drivers on the disc, there for you will have to go to www.dymo.com for current drivers, but unistall the printer from you decktop,pc before installing.
Apr 23, 2008 | Dymo LabelWriter 330 Thermal Printer
Dyno Labelwriter 330
Here is the link for your software. Just scroll down to get to your operating system and you can download everything you need. Hope you weren't waiting long. If this solves your problem please rate this as fixed. So many people forget. If you need more help just add a comment and I'll be glad to assist you further. Thanks. Please,dont forget to rate as fixed. Have a nice day.
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Apr 20, 2008 | Dymo LabelWriter 330 Thermal Printer
Dymo LabelWriter 330 print problem
Try first unplugging PC power cable for 5 mins. Unplug Dymo usb. Plug everything back and restart.
If it does not work, then do the following.
Uninstall the printer completely, also remove all Dymo printer software. Then restart the pc and re install all sofware and drivers. Start installation with Dymo disconnected.
regards
Mar 01, 2008 | Dymo LabelWriter 330 Thermal Printer
Dymo LabelWriter 330 Thermal Printer Logo
27 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
