Question about Haier HRT02WNCBB (17 cu ft) Compact Refrigerator
Haier hrt02wncbb compact refrgerator will not cool
3 Suggested Answers
  • 12 Answers
SOURCE: Haier Model HRT02WNC compact refrigerator not cool...
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
Posted on Jan 09, 2011
rabbitbrains
  • 575 Answers
SOURCE: My Haier compact refrigerator suddenly stopped cooling.i cleared ice buildup and returned power to it .waited 30 minutes and still not cooling.what can I check
Check if the compressor fan motor is engaging. If the fan is not spinning then the coil will freeze up again. Also check that there is enough air movement around the fan for circulation. This is also try for the inside fan. Good luck
Posted on Dec 13, 2016
Dec 13, 2016 | Haier Refrigerators
It won't get colder than 54 degrees. Why won't it get cold?
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 25, 2011 | Haier HRT02WNCBB (17 cu ft) Compact...
Cools but constantly runs
you hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Jul 12, 2010 | Haier HSB03 Compact Refrigerator
I have a Haier compact refrigerator (Model: HSP03WNWAWN-01, Serial Number: A205673063 - I defrost it and know it will not get cold. It comes on but will not get cold. I tried plugging in in for 24 hours...
Unplug the unit then turn the thermostat all the way on then all the way off, then slowly move from off to fully on position do you notice a spring popping sound at a certain point? Yes No? if yes turn it all the way off and wait ten minutes then plug back on, notice if the compressor comes on or not. If it does then turn the thermostat to half way on does it cool now? if yes you have the problem solved, if not you have an issue with the defrost circuit and you need tools to test it, if you have an ohm meter let me know and I will help you further. Thanks for using fix-ya
Jun 05, 2010 | Haier HSB03 Compact Refrigerator
Haier Model HRT02WNC compact refrigerator not cooling what type of gas does it use?
May 16, 2010 | Refrigerators
Haier HSB03 does not cool, just clicks, when it kicks on.....
Most of the times the problem is the compressor relay that get stuck , try replacing it (no more than $30) , but if the compressor still clicks and won't start probably is burned out.
Oct 15, 2009 | Haier HSB03 Compact Refrigerator
Haier hrt02wnc compact refridgerator 1.7 cubic
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Apr 13, 2008 | Haier HRT02WNC Compact Refrigerator
Haier bottom freezer
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
Nov 07, 2007 | Haier Refrigerators
Haier HRT02WNCBB (17 cu ft) Compact Refrigerator Logo
71 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
